New to Swaps need info on LS swap in my EK hatch
Wassup I am about to do a swap in my 98 HB but I am really new to swapping motors. What is EXACTLY do I need other than:
Motor/Tranny/Axles/ECU
What mounts do I need? What harness do I need? Shiftlinkage? ETC? Thanks. BTW I did a search and couldnt find ****.
Re: New to Swaps need info on LS swap in my EK hatch (civicrtype)
Basicly you'll need a complete 96-up LS swap. Should have most everything you need.
There are so many topics out there, do a little leg work!
Re: New to Swaps need info on LS swap in my EK hatch (nsxmatt)
actually u might want to try searching "b18b swap" or "b18 swap" because if i'm not mistaken, the search engine on here wont pick up 2 letter words. well that's been my experience with it, and i use it a lot!
<------keeps that number over there down
You need 99-00 SI driver side motor bracket(below timing belt cover) and rear tranny bracket. You can use LS shiftlinkage. You can keep your other stock mounts. You can use your civic harness.
Re: New to Swaps need info on LS swap in my EK hatch (deviant1)
motor, trans, axles, ecu, shift linkage, 99-00 Si rear tranny bracket and driver side bracket, use the teg mount for the front tranny mount (not the top tranny mount - that all civic pieces). use your civic harness as you will only need to extend a couple wires and call it a day.
nope. very straight forward. there is one thing i wonder about tho. an issue i read about with a fuel tank pressure switch with liek 97 and up b18b swaps. i think someone on here has had that problem and the cure for it was an ecu from a different year. not sure which year. i think the member named 97 hb had the prob.
Cesar Gallardo
10-05-2016 11:13 AM
-=ZAK=-
10-24-2008 07:39 AM
CHAMPwhteEK
11-04-2004 03:44 AM
