New ride
Re: New ride (Boost_V)
The ex i just picked up is fully loaded and my hatch was fully loaded they both have sohc v-tec. the si is a hatch and the ex is a coupe but there has to be a reason why the ex isn't a si.
Re: New ride (ke98248)
Here are some comparative specifications on both vehicles, you can see the differences between the two:
http://autos.msn.com/research/...id=-1
http://www.clubcivic.com/index.php?pageid=specs5
Third generation
(EG/EJ)
Production 1992-1995
Assembly Swindon, England
Suzuka, Japan
East Liberty, Ohio
Alliston, Ontario, Canada
Body style(s) 3-door hatchback (EH2/3)
Engine(s) 1.6L 125 hp (93 kW) I4
Transmission(s) 5-speed manual
Wheelbase 101.3 in (257 cm)
Length 160.2 in (407 cm)
Width 67 in (173 cm)
Height 50.7 in (129 cm)
Fuel capacity 38 L
45 L
The USDM Civic Si of 1992-1995 used a 125 hp (93 kW) / 106tq single-overhead cam D16Z6 VTEC engine, which enabled the car to hit 0-60 in 8.5 seconds.[3] VTEC activated on the intake side and not the exhaust side, which was the result of the spark plug blocking the area where the cam follower would be. Standard equipment included 14-inch steel wheels with plastic wheel covers, dash clock, power sliding moonroof, cruise control, power mirrors, power steering, and driver's side airbag. In 1994, a passenger side airbag and rear speakers were added.
Again, different regions adopted different powerplants--the European and Peruvian Si's used a 130 hp (97 kW) D16A9 engine. At this time, however, the Si was not the most powerful variant of the Civic in Europe; Honda introduced to the region the Civic VTi, which featured a 158 horsepower (118 kW) B16A engine. The JDM version SiR carried an even more powerful B16A engine, which made 168 horsepower (125 kW). Civics in Japan using the SiR name included the EG6 (hatch) and EG9 (sedan) Civics as well as the CR-X Del Sol.
Civic Specifications:
92-95 Civic (5th Generation)
CX
VX
DX
LX
EX
SI
engine
D15B8
D15Z1
D15B7
D15B7
D16Z6
D16Z6
displacement
1493
1493
1493
1493
1590
1590
horsepower
70@5000
92@5500
102@5900
102@5900
125@6600
125@6600
torque
91@2000
97@4500
98@5000
98@5000
104@5400
111@7000
compression
9.1:1
9.3:1
9.2:1
9.2:1
9.2:1
9.2:1
valve train
1.5L 8-Valve
SOHC
1.5L 16-Valve
SOHC
1.5L 16-Valve
SOHC
1.5L 16-Valve
SOHC
1.6L 16-Valve
SOHC VTEC
1.6L 16-Valve
SOHC VTEC
curb weight
MT/AT
hb:
2055/na
hb:
2055/na
coupe:
2245/2315
sedan:
2245/2315
hb:
2090/2210
sedan:
2245/2315
coupe:
2490/2490
sedan:
2490/2490
hb:
2270/NA
Third generation
(EG/EJ)
Suzuka, Japan
East Liberty, Ohio
Fuel capacity 38 L
45 L
CX
VX
DX
LX
EX
SI
engine
D15B8
D15Z1
D15B7
D15B7
D16Z6
D16Z6
displacement
1493
1493
1493
1493
1590
1590
horsepower
70@5000
92@5500
102@5900
102@5900
125@6600
125@6600
torque
91@2000
97@4500
98@5000
98@5000
104@5400
111@7000
compression
9.1:1
9.3:1
9.2:1
9.2:1
9.2:1
9.2:1
valve train
1.5L 8-Valve
SOHC
1.5L 16-Valve
SOHC
1.5L 16-Valve
SOHC
1.5L 16-Valve
SOHC
1.6L 16-Valve
SOHC VTEC
1.6L 16-Valve
SOHC VTEC
curb weight
MT/AT
hb:
2055/na
hb:
2055/na
coupe:
2245/2315
sedan:
2245/2315
hb:
2090/2210
sedan:
2245/2315
coupe:
2490/2490
sedan:
2490/2490
hb:
2270/NA
someday i'll take the time to really read through this stuff. I always get tired of seeing USDM is this but JDM is that but EDM is this. lol
swizz977
21
07-18-2009 03:34 PM
jazzdacbiet
19
12-05-2005 12:28 PM
VTECsound
10-07-2005 07:36 AM
