new clutch
new clutch
ok i got a new clutch kit, and it was professionally installed i have a 92 cx hatch, now i was wondering anyone that has the same model as me witht he d15b7, is your clutch really loose?, like it seems when u press on the pedal it doesn't take much pressure to push it down? thanks in advance
Re: new clutch (VvPeachyvV)
i guess i could try draining and re-bleeding them, if anyone could help that would be great (witht he question, i know how to bleed the clutch)
I had a 94 with the same engine. It didn't feel loose. Push down your clutch, and then slip your foot off real quick and let it slam back. Do that like 5 times and I heard that would tighten it up.
Re: new clutch (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila »</TD></TR><TR><TD CLASS="quote">WUT U MEAN BY LOOSE?</TD></TR></TABLE>
Um, it's loose. As in not tight...you know, like **** stars.
if you got a stock type aftermarket clutch & pressure plate, it will be pretty easy to push the pedal in compared to the clutch & pressure plate you had before... i bought a Daiken kit for my hatchy back in the day and compared to stock pressure plate that was in the car, the new one was like butter when pushin in the pedal...
dan
dan
Re: new clutch (94solchick)
yeah it doesn't have much pressure at all, i was searching and seen something about the bolt underneath the clutch pedal i found it, but not sure as what to do with? anyone know?
komat
09-16-2007 08:26 AM
