need some help
need some help
last night i was banging some gears in my hatch and grinded 3rd, then slightly after that, i got stuck in 2nd gear and couldnt get out of second at all. i got it home, as i was pulling up to my house my brakes went out, couldnt build up an pressure on the brake pedal unless car was off, and then i also got it to pop out of second gear. Is it the master cylinder or do you think a tranny problem or maybe both?
Re: need some help
ok now as far as the brakes go check for leaks or low fluid on res. if fluid is low your brakes could b bad or u lost fluid.
and the tranny if u grind in 3rd its prob gonna grind all the time eventually. and it sounds like you neeed a clutch.
allmotorgsr98
Transmission & Drivetrain
12
06-05-2011 10:25 PM
Samuels
01-13-2007 06:36 PM
vtec25
12
06-15-2006 07:58 PM
boostng r
10-02-2005 11:09 PM
