Need a quick response for a quick question.
Re: Need a quick response for a quick question. (97civicdx)
no, you'll end uo with 2 mounting brackets for the brake lines in the front, and as for the rear, the ek rear lca's are thinner then the eg/dc ones, so rear eg strut fork will fit loose. If you must I guess you can use washers in between, good luck
Re: Need a quick response for a quick question. (vtecvoodoo)
So If I am buying koni shocks from 96 ek, it will not fit on my eg, is that right????
Re: Need a quick response for a quick question. (eEKEGg)
it will fit, you just won't have brake line mounts for the fronts and for the backs, you'll have to add washers as he said above. fat washers too, like um around a 1/4" on each side or so.
OliverV
16
06-06-2009 07:48 AM
