need new si brakes, what will swap?
i just bought a 92 si (non-abs) and one of the rear calipers is shot. none of the local junkyards seem to have the right part, so i'm wondering what will work from other hondas in its place. its already a disc brake, so i'm not looking to do the swap as most people are, but will the accord or something brakes fot? i'm not sure that there are any integras lying around, although it looks like they will fit. i really just need something to get it past inspection.
thanks
thanks
Re: (pdiggitydogg)
thanks for the reply, yes, just the caliper and rotor.
are all those options same size? (just as long as they're non-abs right?)
and i assume this means the accord wont fit?
Re: (pdiggitydogg)
i was under the impression that the abs rotors were larger. so if i got 1 abs rotor and had 1 stock non-abs rotor there would be an uneven brake balence. but i suppose 2 abs rotor would be fine
Re: need new si brakes, what will swap? (stealth89hatch)
i've found cross drilled rotors for sale, but the application says:
01-02 Honda Civic all models
99-00 Honda Civic EX and Si
96-98 Honda Civic EX, Si and SiR 2 Door Coupe
94-95 Honda Civic 4 door EX w/ ABS, 3 door Si w/ ABS and 2 door EX with ABS
92-93 Honda Civic 4 door EX
94-97 Honda Del Sol with ABS
90-01 Acura Integra except Type R
and the 92 civic si hatch is not on there. is it actually true that the rotors are not swappable? or is it just an incomplete list?
Anybody correct me if I am wrong, but typically EG Civics, DC2 Integras, and del Sols/CRXs share many of the same parts, because I am pretty sure the Integra and Civic share the exact same chassis (not sure on the del Sol/CRX)...
EJ6_PickUpStix
12
06-23-2021 11:44 AM
kit50si
13
11-18-2006 06:06 AM
RickChew
03-04-2003 07:29 AM
