need help w/ identifying engine harness socket and this specific location please!
i am running a single cam zc, p08. manifold.
i am wondering what kinda sensor/ device goes into this unit in the rear of the manifold. here are pics.
and also... i t has a hose on the rear of the bottom rear block that i have no clue where it supposed to go. and its not the fuel return line. here are pics.
and also i am wondering what is this single harness with one wire (color blue with a red stripe). what connector or device this goes to? this is an obd2a engine harness. here are pics
and also... what harness/ socket is this lead to this. this wire is near the ecu harness/ engine fuse box wiring. (one wire is black w/ a yellow stripe, and the other is a teal color w/ a white stripe.) this is also an obd2a harness. here are pics.
any help gladly appreciated! thanks!
Seagull Management
Re: need help w/ identifying engine harness socket and this specific location please!
As McVtec stated the IACV is whats missing. The connector for it is currently plugged into the IAT sensor (black sensor on the back of the intake manifold) fix that as the IAT sensor runs off a much lower voltage, 5v IIRC, and it will fry once you turn the key to accessory, don't ask me how I know this. The IAT sensor on OBD2 engines was in the intake piping which is probably what the plug in the last pic is for. Both hoses go to the IACV btw.
Hose clamp.
Hose clamp.
Seagull Management
It just looks weird in the pic, the hose clamp just got slid down the hose when it was removed from the IACV. The other larger hose underneath isn't attached to smaller one at all, the larger hose is the coolant bypass hose that goes from the block to the head. I'm pretty sure I know what you're seeing/thinking, its an optical illusion, the big and little hoses aren't connected at all.
thanks guys! gladly appreciated. is the IAT 3 wired or 2 wired?
EGsrHATCH
11-11-2006 08:16 AM
b00st-0wnz
12-06-2001 12:19 AM
