Need help..tranny or clutch???
Old 06-14-2008, 12:04 AM
Nino_eg6's Avatar
Default Need help..tranny or clutch???
hey h-t, i recently purchased an 94 civic ex and i think either my tranny or my clutch is going. the reason i think this is because whenever i put it into reverse it grinds(sometimes) and i cant downshift to second gear wen car is rolling also downshifting to other gears is a struggle sometimes....i cant switch from 1st to 2nd without it grinding or mis-shifting when racing( so at high rpms) everything is fine if i switch at 3k or around there...........so if any of you guys might know what it could be let me know thankz....
Old 06-14-2008, 12:47 AM
Nino_eg6's Avatar
Default Re: Need help..tranny or clutch??? (Nino_eg6)
any1??
Old 06-14-2008, 07:49 AM
roycivic92's Avatar
try dumping the tranny fluid and replace it with gm syncromesh. baby the tranny for a while. normally it will help with the grinding(wont fix).
Old 06-14-2008, 10:22 AM
Civic_07's Avatar
Wow, your tranny is basically done, but if you try that syncromesh stuff it MAY go away.
Old 06-14-2008, 10:24 AM
z6hatchboy's Avatar
Its the tranny, try changing the fluid with syncromesh and see where that gets you, but your syncro's are going out and will have to replaced at some point, so it'll end up being new syncro's or another tranny in the end.
Old 06-14-2008, 11:54 AM
wondersparrow's Avatar
if you double clutch and take your time, does it still do it? if not synchro is likely toast. can you go thru the gears without using the clutch at all?
Old 06-14-2008, 11:56 AM
as well, it it hard to get into gear when stopped? if so, odds are its the clutch.
Old 06-14-2008, 07:51 PM
Nino_eg6's Avatar
Default Re: (wondersparrow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wondersparrow &raquo;</TD></TR><TR><TD CLASS="quote">as well, it it hard to get into gear when stopped? if so, odds are its the clutch.</TD></TR></TABLE>
yea i mean if i play through the gears before putting it in reverse its find...when im stopped and i put it into first , and soo on its okay, it only grinds when im shifting at high rpms or when i put it in reverse without playing through the gears first....
Old 06-14-2008, 10:12 PM
change the fluid and be a little more patient on shifts and she will last you a long time.
Old 06-14-2008, 10:29 PM
Nino_eg6's Avatar
alright thanks wondersparrow...what fluid do u recommend???......yea i just need her for now as a DD while i get enought to buy a new tranny n turbo her....
Old 06-17-2008, 07:26 PM
Nino_eg6's Avatar
Default Re: (Nino_eg6)
Old 06-17-2008, 07:46 PM
elektronsi's Avatar
OEM honda MTF, GM syncromesh
Old 06-17-2008, 07:48 PM
I havent really tried any other fluids other than the honda stuff. Learn how to double clutch as well and that will help make it last longer.
Old 06-17-2008, 08:16 PM
Nino_eg6's Avatar
[QUOTE]OEM honda MTF, GM syncromesh
QUOTE]
would i mix these fluids together or use one or the other..... also can you give me a tip on double clutching
Old 06-17-2008, 08:39 PM
its simple. step on clutch, shift to neutral, let off clutch (this forces the gears to sync up, required in syncro-less trannys), step on clutch again, shift to desired gear, let off clutch.
as well there are points where you can easily change gears without a clutch at all (3.3 - 3.4k rpm on my setup), if you learn to shift at those points (while still using the clutch), there is virtually no strain on the transmission. I had a completely borkt transmission last like a year using those techniques.
delsold16
09-22-2004 07:19 AM
svtec
05-20-2003 10:21 AM
Proper
04-23-2003 04:55 PM
makaveli284
10-02-2002 09:53 PM
phatintegra
12
03-20-2002 05:37 PM
Quick Reply: Need help..tranny or clutch???
