Need help!! running problems
I have a 95 civic hatch with an f22 accord swap non vtec. I'm running a VX hatch wiring harness. It starts and idles fine, drives fine until I hit 3500rpm and sounds like it is hitting the rev limiter and will not accelerate past that. Timing is set on the dot, fuel pressure and all. Any suggestions as to what it is? I'm running the accord ecu. the only trouble code I get is the o2 sensor.
Re: Need help!! running problems (90dteg)
i got the same problem with my civic hb i put a b16 in it and it does the same ****, i have no clue whats wrong, i would think its the settings on the ecu
grammer nawzi
Re: (90dteg)
What you want to do is take large steps and make sure that you increase your leg speed until you can't move them any faster. I prefer left leg first then right, then left then right then left then right . . . and so on. Hope that helped.
Re: (90dteg)
well once again, i have the same problem and i need help, im only 16 years old and i did this jdm b16 swap all myself and im so close to makin this car work perfect but the freakin thing loses power at 3500rpm, im so frustrated damit
13g-crx
14
03-02-2007 09:53 AM
wsriane
17
07-29-2006 01:59 PM
