NEED HELP!!! no spark. no start
ok 95 dx civic with z6 swap (did swap a year ago). just put a jrsc the other weekend and it started right up after install. then igniter aka ignition control module took a **** on me so i jsut replaced it tonight along with new cap and rotor. plugs and wires are also good. just tested coil and its within spec.... what do i check or replace next??? need help. thanks in advance
HT Order of Merit
Re: NEED HELP!!! no spark. no start (95dxhatch)
Check the ground on top of your thermostat housing. This is where the ECU grounds, if this came loose, or has a bad connection, yo **** wont run.
Re: NEED HELP!!! no spark. no start (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Check the ground on top of your thermostat housing. This is where the ECU grounds, if this came loose, or has a bad connection, yo **** wont run. </TD></TR></TABLE>
:thumbup
Exactly what i was going to say. Does it crank at all?
:thumbup
cranks but doesnt start. no spark. fuel is good and i've got air. have 2 of the 3 things needed
EDIT: checked all grounds and everything is good
Modified by 95dxhatch at 1:54 AM 7/15/2005
SI_niki
11
06-13-2004 05:02 PM
dblack
04-27-2004 01:54 PM
