Need help with my Wierd AC problem. Condenser fan not spinning and compressor switching on and off
Old 08-06-2008, 04:23 PM
stockEJ's Avatar
Default Need help with my Wierd AC problem. Condenser fan not spinning and compressor switching on and off
Need help from AC experts.
I have a 96 civic lx.
First the AC condenser fan never comes on.
When car is on in idle, I can hear the AC compressors clutch switching on and it will run for about 10 secs and then shut off. It repeats this sequence over and over sporadically.
The Low pressure valve connection to the compressor had some greenish fluid inside of it bubbling out when I took off the blue cap. I wiped that clean and I haven't seen any green fluid since.
When the car is in idle, the AC is warm.
When I drive it even at just 20mph, the ac is ice cold.
This leads me to believe that there is enough r134a in it.
Any ideas of what the problem can be other than the compressor fan not coming on? Could low r134a cause the fan not to come on?
Last thing.. if I need to check the ac condenser fan, how do I do this safely because I noticed that the high and low pressure compressor hoses would need to be removed for that job and I don't want to have that **** blow up in my face. Thanks and sorry for being
Old 08-06-2008, 04:25 PM
AnotherSI's Avatar
Default Re: Need help with my Wierd AC problem. Condenser fan not spinning and compressor switching on and
dude i just spent ten minutes tellin ya what to do with the last thread you made....
Old 08-06-2008, 04:27 PM
Seagull Management
94EG8's Avatar
yeah man, you've posted 4 identical threads, please don't do that.
sageuvagony's Avatar
There are 4 open threads now which are exactly the same. I also explained in detail what the problem is and why stuff happens... The first 2 topics are already answered, and were posted earlier than this one.
Old 08-06-2008, 06:46 PM
RyanA's Avatar
And #3. Maybe you should just cancel your trial. EPIC FAIL for you.
rahu
04-30-2018 10:27 AM
Single-Cam
16
02-10-2016 07:23 PM
94_civicEx
Honda Civic (2006 - 2015)
06-13-2014 12:28 AM
stockEJ
08-06-2008 06:45 PM
whitenameseboi
07-14-2004 10:11 PM
Quick Reply: Need help with my Wierd AC problem. Condenser fan not spinning and compressor switching on and off
