Need help on how to remove stripped arp head bolt
Old 03-21-2012, 08:49 AM
tensaiwung's Avatar
Icon6 Need help on how to remove stripped arp head bolt
Ok so i have a gsr that i was gonna do a headgasket on. As i went in to remove the last arp head bolt. It stripped on me!?? So i need some info asap on how to get this out. The nut is totally rounded. Tried 2 forms of easy out, drilling, and hammering in a socket thats a size smaller to bite onto the rounded nut, and i used the allen wrench or hex socket and stripped that part of the bolt itself also. sadly nothing works and its a tight space. Any advice?? Thanks.
Old 03-21-2012, 09:14 AM
Sol2Take's Avatar
Default Re: Need help on how to remove stripped arp head bolt
Maybe filing a a nice groove in it and using a flathead? Pound a chisel underneath the bolt head?
Old 03-21-2012, 09:22 AM
gold_pwr_r4ng3r's Avatar
He'll f*** up the head if he does that. OP dont listen to this bad advice^
tensaiwung's Avatar
I was thinking of that also but doing it from the top and making look like a flat screw but it might not work due to the bolt being torqued down. Dam its so hard.
Old 03-21-2012, 09:25 AM
You may be able to drill the head off the bolt and slide the head off the block and you should be able to get at the bolt easier.
Old 03-21-2012, 09:26 AM
kyden's Avatar
have you tried a socket for removing stripped bolts? (an actual bolt out set)
motegicivic's Avatar
Can you take a picture?
Any head left maybe one of these?
Old 03-21-2012, 09:28 AM
x2
Old 03-21-2012, 09:34 AM
tensaiwung's Avatar
Yeah i tried that. Didnt work. I melted all my drill bits trying to drill this thing out
Old 03-21-2012, 09:45 AM
Take a picture, easier for use to gauge on what to use.
jbpnoman's Avatar
If you used a cutting wheel to put a slit in the head for a flathead screw driver, you could use a screw driver made for a ratchet. That would alleviate your concerns about torque. Worst case scenario it snaps off the head, then you can just pull the head off and use a stud remover.
Old 03-21-2012, 09:53 AM
cctgene's Avatar
I've had good success with the Lisle stuck bolt, nut & stud remover tool. However, never use it on a head bolt.
http://www.usatoolwarehouse.com/usat...LIS-19250.html
Old 03-21-2012, 09:54 AM
JDM_teh_WIN!!'s Avatar
I have a full set of these and they work GREAT!!!! Definite must for working on cars with rusted to f*ck nuts and bolts. Also good if you don't know how to use tools and strip bolts a lot. Haha.
Old 03-21-2012, 09:55 AM
EK9
Dc4LsTeG's Avatar
Im sorry but how did you strip a 12pt nut?
Old 03-21-2012, 10:51 AM
pityocamptes's Avatar
Buy a cheap *** extension and weld the extension to the bolt head (not one long weld bead, but small numerous ones (keeps heat down)) - problem solved. Just make sure you put a wet rag around the head while welding to keep the heat down. Let it cool naturally (the bolt/weld) - cool to the touch - before attempting to remove.
Old 03-21-2012, 10:55 AM
kyden's Avatar
^^ there's no way you're gonna be able to weld there.
Old 03-21-2012, 10:58 AM
Arthas's Avatar
Same question im wondering...
Old 03-21-2012, 11:08 AM
^^^^ Why not? Cover the surrounding area adequately and have someone who knows what they are doing...
If it looks like this:
http://media.photobucket.com/image/h...00622-1253.jpg
Old 03-21-2012, 11:09 AM
tensaiwung's Avatar
I honestly have no clue?? Just tried loosing it with a 12better point 13mm socket and it rounded off
Old 03-21-2012, 11:11 AM
kyden's Avatar
because it's a gsr motor.
Old 03-21-2012, 11:14 AM
Anyone have a pic? OP - pic?
Old 03-21-2012, 11:15 AM
This?
https://honda-tech.com/attachment.ph...1&d=1269147952
Old 03-21-2012, 12:29 PM
EK9
Dc4LsTeG's Avatar
It's a 12pt 1/2"
Old 03-21-2012, 12:40 PM
Standard bolts in a metric car???
Old 03-21-2012, 01:20 PM
EK9
Dc4LsTeG's Avatar
Its ARP. Thats what size mine are in my B18C5. And my ARP rod bolts were standard size also.
Quick Reply: Need help on how to remove stripped arp head bolt
