need help " GIZZMO LAUNCHER INTERFACE"
Well i just bought this gizzmo launcher interface from some one here on ht.. But i do not know how to install it... I can go to a pro.. But my car isnt running at the moment..and i want to se if i can do it at home.. I can put all the ecu wires its just i dont know how or where i can connect the plug that reads the clutch pedal...... I'll post pics up asap/// please some one help
Re: need help " GIZZMO LAUNCHER INTERFACE"
oh.. i know how to wire it up.. the thing is .. snce i bought it used im not sure if its missing a sensor.. or if the sensor is already on the car, it come with this sensor attached with the gizzmo this that reads the clutch sesor to see if the clutch is activaed...
http://www.gizzmoelectronics.com/pdf...%20Ver1.02.pdf
look at under were it says "CLUTCH SWITCH"
under that there is a pic of 2 blocky things.. 1 with a wire and one without.. i have th 1 without .. im not sure im im missing the other 1 or if that 1 is on the car
Yes, it came with a switch. However if you have cruise control you might could use the switch, or tie off the clutch switch and use it, or just go by one. The switch it came with should work like any switch, itll either be close or open to tell whats what
im sorry but can you xplain it a little more. i didnt really get it.. sorry kinda slow.. :{
