need help fast wit tail lights
hey whats up.....just got a 92 bubble after tradin of my lovley ef ...the problem is the tail lighs are out and so is the light on the hatch wing..but the turn signals work u think its a fuse?? if so what one to i check please help asap just got pulled ova for it
Re: need help fast wit tail lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">if thier was a diagram to look at i woundnt of ask </TD></TR></TABLE>
none on the fuse box cover or in the owner's manual?
Re: need help fast wit tail lights (slowassciv33)
i neva got the onwer manual wit the car i just picked it up last night ..tha light worked then but wont work now...i tryin to check the fuse but i dont wanna pull ever one out
do you have a test light? The fuses have two tabs on each side where you can stick the sharp end of the test light and touch it. Make sure the switch is on and turn the lights on, touch both sides of the fuse with the test light and see if the light comes on, if one side doesn't come on there's your problem. And don't forget to connect the wire end of the test light to a ground or it won't work.
Re: need help fast wit tail lights (Kista20)
i dont have a test light...but the cluster turns on let parkin lights work and the blinker works could it still be the fuse??
yes it does sound like a fuse or it could be the wiring but always check the fuses before the wiring. Wiring doesn't go bad that often unless someone has been in there and done crap. Get a test light, they are very cheap and a couple of bucks will get ya one, also have you used one before?
a test light i neva used b4...neva eva had to worry bout wiring wit any of my civics and this would be easy if teh diagram was on the panel but its not
ok when you look at the fuse, the blade type fuses are a lot easier to tell if they go bad. The round type can go bad at the ends so it's sometimes hard to visually see if it's bad or not. Fortuneatly everything today is blade type, although I don't like the mini blade near as much as the regular ones. If you look at the fuse where the amp rating is where is says 10,15,20,25,30 whatever it says, on each side of that are the tabs where you can stick a test light into. If you plan on doing any kind of electrical work they really come in handy. Also I thought the fuse you should be looking for is a 15 amp, thats what most of them are. But pull one out look at it and put it back if it's good then pull another. Also if you have a fuse puller it makes it a lot easier getting them out.
its suppost to be a 15??? ill check i pulled a cuple 10s and the loked fine thier was no burn marks on them
I'm going to go outside and get my cover and look at it and I'll brb. Mine is a 97 hx so the location is more than likely different but the sizes will be the same. The "z" part in the middle of the fuse is where it burns out.
yea i check probaly like all the 10 and 15s and the "z" part looks fine i just dont understand mayb the radio wires that werent taped up might of shorten itout? im not sure this is my first eg i always had efs
ok does your license light work? On my cover it lists the tail and license light together on a 7.5 amp fuse, running lights is a 10 amp, and 7.5 for turn signals. I guess I thought 15 because most vehicles have more features on one fuse. Honda really divides it up, hence the smaller size fuses. You didn't tape up the radio wires? Well they would def. short something out if left bare.
Moderator
there is!!! it is on your fuse panel cover!!
the license plate lights on the tail lights turn on when the lights are on to all is workin excpet brake lights
Re: need help fast wit tail lights (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">in teh interior???? i have the panel in front of me wit no diagram</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">
there is!!! it is on your fuse panel cover!!</TD></TR></TABLE>
ummm he has the cover but not the plastic insert that tells him where everything is. At least mine is has an insert, is it the same for 92-95?
does your horn work? under the hood next to the battery on mine is a black plastic box. It has a bunch of fuses and relays. It lists the horn and stop on a 15 amp fuse. Those should be listed on your cover.
the horns not hooked up the put a aftermarket steering wheel ill try the fuses under the hood in the morning
