NEED A/C Compressor Bracket
My vehicle : 94 civic hatch
Engine swap, now has a b16 (i believe it's a del-sol engine right?)
I have a compressor that should mount to this engine for my A/C... HOWEVER, the bracket I have right now to mount it is from the old engine.
DOES ANYONE HAVE A BRACKET THAT WILL FIT ON MY B16 ENGINE???
I've tried bolting it on with just 2 bolts and it eventually broke off. Someone has to have one of these.
Re: NEED A/C Compressor Bracket (thesilverfox)
if your b16 engine swap is from a del sol vtec model then your d series ac compressor should bolt right on with no problem..
is your b16a jdm that comes with p30 ac bracket ? or it is a usdm ?
Re: NEED A/C Compressor Bracket (crazyguy)
yes.. i know, but the bracket is different. the bracket won't allow me to.
the compressor is the perfect fit, BUT without the proper bracket (i still have the old one from the old engine) it won't fit
is your b16 swap jdm? because jdm del sol b16a and usdm del sol b16a ac brackets are different..because my jdm b16a came from a del sol in japan and i had to do some modifications and tried various ac brackets and compressors to make my ac work.
the photo shown below is from my engine.if u look closely..u will see B16A stamped on the engine block..that means it is JDM..but if u see B16A1 or B16A2 that means it is usdm..whatever with a digit number after B16A is usdm model
ok. ty. i will check to see what my motor says...
i'm still pretty sure i'll need a bracket though. we shall see.
Re: (Luserkid)
^^^^^what he said...when running a sohc compressor a p54 or (p2j<??cr-v??) is used....i have a b series brack and compressor for sale if your interested... guaranteed to work!!! https://honda-tech.com/zerothread?id=2108144
Re: (ricekiller1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">is your b16 swap jdm? because jdm del sol b16a and usdm del sol b16a ac brackets are different..because my jdm b16a came from a del sol in japan and i had to do some modifications and tried various ac brackets and compressors to make my ac work. </TD></TR></TABLE>
umm not to be a dick, but arent all JDM motors from japan.. hence JDM meaning JAPANESE DOMESTIC MARKET
okc
05-01-2011 07:56 PM
bboyjimpy
15
01-18-2010 07:44 PM
RCautoworks
24
07-25-2005 03:58 PM
