My mini me 1/4 times...correct or awful?
wow, okay, so...i know when doing the mini me swap, theres the oil feed plug between cylinders 2+3 that your sposed to yank out to activate vtec...now, i bought the car with a mini me swap in it..and im not to sure if the people knew what they were doing when they were putting the motor together. What it is is a 95 dx hatch with a d15b7 with a z6 head, AEM cai, stock exhaust all the way back and a stock p28 ecu. I decided to run it at the track to see what kind of times it would pull, and heres how it went...
rt - .568
60 ft - 2.485
1/4 et - 16.9
1/4 mph - 79.5
Is this right for my motor, or do you think that the oil plug was never taken out..thanx a lot for the help, im kickin myself in the *** over this
rt - .568
60 ft - 2.485
1/4 et - 16.9
1/4 mph - 79.5
Re: My mini me 1/4 times...correct or awful? (VTiHatch)
it seems a little high, but there are other factors involved. your 60 ft time is a little high, which could set your time back a little bit. ive seen other people with similar engines (mini-me's or d16z6/y8, which are all roughly similar in hp output) in dx's run like mid 15's, but they had a few more mods done. overall i think that your setup should be runnin at least low 16's. just outta curiosity, what track did u go to- im pretty local and was wondering where people went around here.
Re: My mini me 1/4 times...correct or awful? (blackeg)
my friend with a cx gutted hatch with a carbon fiber intake, dc sports header, a test pipe, a apex i n1, and B&m short throw ran 16.3. His car weighs 2000 lbs w/o driver,. and he weighs like 200. oh yeah that is on hx rims with **** tires. and like a stage 2 clutch.
Re: My mini me 1/4 times...correct or awful? (SOHC_MShue)
its a y7 block with either a z6 or a y8 head. and a y8 intake manifold. he is still running a cx/dx tranny though.
Re: My mini me 1/4 times...correct or awful? (sohcvtec1995)
its your tranny. Get a 92-95 si or ex tranny or 96-00 ex tranny. Your gearing will be way shorter. Your gears now are way too long and it will accelerate slow.
yeah i know its not my car. it is my friends car. i already have a ex. like it says in my sig. but he is going to get a jdm h22 soon. and he just got some new tires. and he is waiting on his brother to put the order in. He works a Titan.
Risky Business
Re: My mini me 1/4 times...correct or awful? (iwhichisme)
yeah...I did a mini-me...and didn't pull the oil jet...heres what happened...(note this is a 2300 lb 4 door)
Stock B7 I/E, shifting @ 6600
Temp: 60+ Degrees Nighttime
60ft: 2.4
1/4: 16.9
MPH: 80
B7 w/ Z6 head, no removed oil jet, I/E, shifting @7200
Temp: 90+ Degrees Daytime
60ft: 2.4
1/4: 17.3
MPH: 78
(Yes, I know I'm a shitty drag racer, i'm workin on it)
Point is, I ran almost half a second slower with the non-working mini-me than I did with the stock B7...
60ft: 2.4
1/4: 16.9
MPH: 80
60ft: 2.4
1/4: 17.3
MPH: 78
Re: My mini me 1/4 times...correct or awful? (BauleyCivic)
aight thanks guys...this sucks, gotta go rip off te head now...oh, and blackEG.. i ran it up at lebanon valley...oh well, wish me luck...
Solbros Owns Me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">its your tranny. Get a 92-95 si or ex tranny or 96-00 ex tranny. Your gearing will be way shorter. Your gears now are way too long and it will accelerate slow.</TD></TR></TABLE>
I went from a 15.5 to a 16.2 in my 94 Si after I blew my tranny and threw in a DX tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTiHatch »</TD></TR><TR><TD CLASS="quote">im not to sure if the people knew what they were doing when they were putting the motor together. </TD></TR></TABLE>
Maybe you cant drive....Motors put together fine runs mint.So they didnt pull the oil plug thingy. No one researched it or really cared had to get the car running to sell.
Gotta love the D-series...
Seriously though, I think that this might be a driver problem, not an engine problem. That 60 ft time is awful. Get that down to a 2.2 and then if you are running bad times, you have a pretty good idea that it might just be the engine.
Re: (explosive)
Im running 16.3 in my 94 coupe w/z6 motor.(BAD RINGS AND SMOKES HORRIBLY). launch rpm 3500, shift rpm 7000
(NORWALK RACEWAY PARK, OH)
R/T .505
60' 2.482
330' 6.936
1/8 10.561
MPH 68.75
1000' 13.706
1/4 16.332
MPH 85.84
header/converter/cat-back/short ram intake/no internals yet(this winter)/no head work.i know the times arnt where they are supposed to be but the motor isnt there either.
R/T .505
60' 2.482
330' 6.936
1/8 10.561
MPH 68.75
1000' 13.706
1/4 16.332
MPH 85.84
Location: The Village Hidden in the Leaves: Seattle, WA
i ran a 16.2 in my 99 ex :D i don't have my time slip with me, so i don't remember all that crap. lol but i just had my car lowered on sprint springs and tokico illuminas. i remember i had a bad reaction time, like 1.02? and a 60 ft of 2.3. and i trapped at 85 almost 86mph.
Re: (LiTtOGPiMp)
I am running the the same 60' (2.419) in a '92 cx w/d16z6, dead clutch n shitty street tires but pulled a 15.525....i would say its a combo of the motor n the driver
....Got new tires and new ACT clutch n flywheel setup, waiting to go back n see the difference (ran a 15.43 on g-tech, which is suposidly only of by a hundreth of a sec...??)
watacivic
13
03-01-2003 12:58 PM
92cxgsr
03-01-2002 05:38 PM
