My header is cracked.
Well my stock header is cracked. I need to find a new lx header with two o2 senors. So far from my searching, I only found out a RActive header with two o2 sensors. Is there anywhere else that i can find a header with 2 o2 senors? Greddy and other companies only makes Ex headers with one o2 sensor. Help? It is for a 98 civic lx.
[Modified by CereaLand, 5:46 PM 3/19/2003]
Re: My header is cracked. (CereaLand)
I had this same problem. I have a 1998 Honda Civic LX. Your best bet is to find a used one off someone here in Honda-Tech. My header cracked at around 65,000 miles. I purchased a used one off here for $80 and I had it put in for $40. No problems since then. Going aftermarket will cost you like three times as much. Most of the aftermarket headers are made for the EX, HX, and Si. You can not use these headers unless you remove your cat. This is illegal of course, so this is not a very good option. If you want to fix it for cheap...just get a used one and have someone put it in for you. You'll need to get two new exhaust gaskets, one for the down pipe and one for the exhaust manifold. Hope that helps.
im sure all you need is a regular header with 1 o2 sensor in it because the other should go on your cat.
Re: My header is cracked. (pennies_hatchie)
i thought there was only 1 o2 sensor on the header and 1 on the cat (making it 2 total)
Re: My header is cracked. (02DC5)
i know a guy that has a 97 civic and his header cracked on his POS dx engine and it was covered under warranty still.. dont know how or why but it was.. he is saving for a swap tahts why he didnt want anything new for the motor..
YEE*MagicEK20kombobomber
02-29-2004 08:04 PM
