My DelSol Project - tire wear problem
So hey guys ive had this Sol for awhile i forgot about it cuz i was on a EJ1 but i sold it but now im back on the Sol this is what ive done so far i just have a problem with my wheels i wasted new tires in one month it pisses me off idk whats wrong with it,
When i got it
The next day Shaved bumper
On the site
The Motor is out!!!!
Re-Painted Bay
Ima Paint it white and slap on some DR20's even tho their played out
When i got it
On the site
Re-Painted Bay
Re: My DelSol Project
So yeah like i said my tires get waised like in a month its lowerd on some tokiko blues but idk whats wrong my other civic drives fine. Any idas
Re: My DelSol Project - tire wear problem
Thread titles MUST state the tech problem (be subject specific):
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
I edited the title this time.
camber wont eat tires so fast ... from the condition ot the tires it is "toe out" situation ... nothing a good alignment wouldnt fix ... unless sub(frame) is bent
negative, camber WILL eat your tires if you drive regularly with this vehicle. i have a bad camber in the rear of my del sol but due to the fact the car gets rarely driving its obvisously not going to be eatin away that quick
Definitely an alignment.
But also check your clearance, remember then even though you lowered your car, 10-1 your suspension isn't as tight as you think it is and when you hit a bump your tire hits the fender (roll your fenders if need be) or even bottoming out in the well.
My del sol went from being 6" off the ground (6" measured to the bottom of the side skirt) to 3". I noticed my front right is lower by maybe 1 or 2 turns and it rubs on the fender when I turn left and right so now my front right tire is slightly feathered on the outside. The camber is mad off (-1 to -2?) and I have 0% camber wear on it. Measured the thing and still got close to original tred left (hells yeah).
A camber kid should only be used if you plan to actually tune your suspension a certain way IE front is negative and rear is neutral or some other setup........
EDIT: Didn't see the post but another member said....
"camber wont eat tires so fast ... from the condition of the tires it is "toe out" situation ... nothing a good alignment wouldnt fix ... unless sub(frame) is bent"
THIS^^^^^^^THIS
THIS^^^^^^^THIS
So im back for some help i went and bought new tires and camber kits but before i left to alignment i saw this half inch lip inside my fenders wall like almost touching my tire is their anyway of removeing it? pics if u have some?
look towards the arrows lol.
my tire scrapes on that same spot on my ej1! but i think my strut is out cuz its only on the driver side(even with a passenger it doesnt rub on that side)
i think i hammerd mine in but half ***
i havent tried hammerin it all the way down but it does scrape in my tire
im in the same boat!
So heres some pics of my camber upgrade+and lip bending what should i do next to reduce tire weare?
the lip that hits my tire
after some hammering
and after i installed everything back
And i also found out how these camber kits work how much should i sell them for lol
lower profile tires have been known to go faster. Just saying what i have seen and been told.
unless your runing a **** load of camber you really shouldnt have too many problems with it. Have your toe set at 0 or oem spec.
