my del sol Radiator never stops leaking
well it isnt leaking the hoses are, first i have a b18c1 and the del sol dual core auto Radiator. I have the transmission coller running in a U with no problems, but the the main hoses couplings seem to leak, am i supposed to get differnt hoses. also how do u bleed a Radiator. I did search thanks in advance
Re: my del sol Radiator never stops leaking (SiRcyrusEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRcyrusEH2 »</TD></TR><TR><TD CLASS="quote">well it isnt leaking the hoses are, first i have a b18c1 and the del sol dual core auto Radiator. I have the transmission coller running in a U with no problems, but the the main hoses couplings seem to leak, am i supposed to get differnt hoses. also how do u bleed a Radiator. I did search thanks in advance</TD></TR></TABLE>
To bleed the radiator of air bubbles, there is this little nipple like thing near the block. It`s between the block and the upper radiator hose that attaches to it.
Turn the car on, slowly turn the screw counter-clockwise and the coolant should slowly start to flow out. Once you get a steady stream, tighten the nut and you`re set.
Re: my del sol Radiator never stops leaking (Bakeoff)
yeah im using the thread clamps, do u think bleeding could casue it, does anyone have a pic of hte nipple ill check my helms manaul thanks
delsolrob
10
04-27-2004 08:57 PM
