My b16a2 dyno numbers *finally*
b16a2
short ram intake
4-1 hella DENTED header
testpipe
RS*R Catback
~70000 miles
even compression numbers
"mugen" chipped p28
as you can see it's a little lean according to the wideband there
plugs are just slightly brown with no signs of detonation or overheating.
I have the .bin if anyone wants it.
I also tested the "j's racing chip"
it made less power everywhere (2-3) and was a lot richer, to rich in some parts.
turbo is going on in a few weeks, my goal is another 100whp and finally some TORQUE!
finally
short ram intake
testpipe
RS*R Catback
~70000 miles
"mugen" chipped p28
finally
I'd say it's a bit too lean . Especially since it will be even more lean when you're driving on the road and not just on a dyno.
Get it down to 13 or so and you're safe
Guest
Posts: n/a
Re: (Jumpmann23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jumpmann23 »</TD></TR><TR><TD CLASS="quote">uberdata? or chipped ecu?</TD></TR></TABLE>
Pretty much same thing really.....just constant flashing...
Anyways, richen it o-so-slightly 4.2-5.2 Don't touch anyhting after that, and see if that makes a differences. Good luck.
Re: My b16a2 dyno numbers *finally* (976)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 976 »</TD></TR><TR><TD CLASS="quote">No such thing as JDM B16A2 correct?</TD></TR></TABLE>
you you are correct. In japan there is no number after the letter. It's just a b16a or b16b there.
Global Moderator
Re: My b16a2 dyno numbers *finally* (Lil Corb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Corb »</TD></TR><TR><TD CLASS="quote">
you you are correct. In japan there is no number after the letter. It's just a b16a or b16b there.</TD></TR></TABLE>
Yes your correct JDM B16 = b16a
Re: (Ekizzle)
the valves are tight BTW
.005 and .006
about the max you can go i think. feels better like this than at .006 and .007
i adjust the valves every 10k
oil every 2.5k
regap the plug every oil change, new ones every 10k
dissy and plug wires are 70,000 miles, no probs!
getting ~25-30mpg
.005 and .006
oil every 2.5k
getting ~25-30mpg
Re: (Sketch_hs)
turbo si and uberdata . i see you dyno'd at atp. ive bought some **** from them, and some of my crazy turbo vw friends have numerous atp **** in their setups
