My 95 Civic CX hatch build
#126
talks to himself
talks to himself
Re: My 95 Civic CX hatch build
Slow and anything but steady progress...
I received my Head from the machine shop and took the dive and bought a header. I also finally got around to replacing two pieces of my suspension. I tried installing my rear sway bar end links but the bolts were too large. I don't know what's up with that. Preliminary searches have only returned one other person with the same problem and no resolution. I'll search more before posting a question. I also began taping up the block for paint.
Now for pics.
Now for pics.
#131
talks to himself
Tapped off the head last night and FedEx tracking says my universal plug set and engine paint should arrive today. Hopefully I can make some progress tonight. I want to be able to let the paint sit on the engine for at least 24 hours (based on nothing because I don't know much about painting) before I begin reassembling engine.
If you're selling any accessories, let me know what you have. I need a catch can, battery re-locator box, window moldings, and carpet to name a few. Maybe you have something I've forgotten about.
#133
talks to himself
Remove the Motor and Transmission, Axles, Rear Engine Mount, Engine Harness and ECU and install them in the Del Sol. You may have to add some wiring from the ECU to the engine harness connectors. Maybe not since you're already wired for SOHC VTEC because you've got a D16Z6 engine, right?
Search the form for specific questions relating to your swap. Engine swaps of this type are common. If you search, you'll find what you need. I'll start you off with this link: https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A%2A%2Aokay-lets-cut-down-repeated-qs-about-certain-swaps-post-links-here%2A%2A%2A-650230/. Good luck!
#134
talks to himself
My Eastwood paint order came in yesterday so I finished preparing my head and block then took it to my Uncle’s house where my dad and I shot it. The color is “Universal Aluminum” and it’s a part of Eastwood’s engine paint line. Application is easy. It’s a 4:1 ratio with its “Activator” (aka hardener). Surfaces were cleaned thoroughly first and prepared with a scuff pad and Eastwood’s “Pre”.
I DID paint the block and the head. My dad just doesn't take pictures. Ever.
I now have parts of my car in three (3) separate houses and a total of six (6) rooms.
Before
During
Head
Before
During
Head
#135
They're basically the same car. I think you already have everything you'll need.
Search the form for specific questions relating to your swap. Engine swaps of this type are common. If you search, you'll find what you need. I'll start you off with this link: https://honda-tech.com/forums/showthread.php?t=650230. Good luck!
#136
talks to himself
What's the difference? Length?
#137
He needs 93-97 Del Sol VTEC (not Si) shift linkages. Majestic Honda ships them for around $200. Length is the difference. All B-Series transmission have the same mount for the linkages.
BTW...great build...keep it going. I want to see the SC on the engine next!
#138
talks to himself
talks to himself
Thanks dude. It's been a journey so far and I've still got quiet a ways to go. The best advice I can give anyone is to have patience.
This weekend's to-do list:
Because I'll be assembling everything in my basement, I won't be torquing anything down. The purpose is to mock up the engine assembly to make sure I haven't lost anything over the past year. Like I've stated in a previous post, parts for this car are literally strewn all over the place. I need to pull them all into one place and identify what I've lost and what needs to be replaced.
The engine will sit until spring when I can assemble it in the car. I don't have a heated garage so working this winter will be pretty miserable. I'll get a heater if I need to but, I'd rather not. Who knows, maybe the engine assembly will go smoothly and maybe I'll have time to tuck and shave the bay this winter. I doubt it, but a man can dream.
- Paint FMIC
- Mount FMIC
- Assemble Head
- Assemble Block
- Mount Intake Manifold/Super Charger and other block and head accessories
#145
talks to himself
Aw, come on. You can't still be excited? I'm not sure what a double plenum would do. Actually, I'm not even sure what you're talking about, to be honest... I can't even envision it. You're not talking about a setup that has two throttle bodies, are you?
#147
talks to himself
I haven't gotten much done today. The weather was so nice I decided to wash and wax my daily (6th Gen. Hatch) and my fiance's car. Ended up washing my mom's car, too.
Also, I got sucked into reading about engine systems. I haven't yet figured out 100% of my build. I was/am still relatively uneducated on the evaporator system and the positive crank case ventilation system. So, I've been reading. Scouring the internet with my Helm's manual at my side. It's one thing to buy a **** load of parts and slap them together and it's another thing to understand WHY things go together a certain way and HOW they work. Understanding this helps troubleshoot down the road and limits the number of stupid questions I'll have to post.
For example, in this post: https://honda-tech.com/forums/showpo...&postcount=102 I ask Honda-Tech what all the crud in my intake runners was from. I never received an answer however I now understand that this is a result of oil vapors from my crankcase and even my valve cover when under heavy load.
The following threads provide an excellent description of the PCV system and why we run Catch Cans.
Thread 1: https://honda-tech.com/forums/forced-induction-16/tests-pcv-system-how-honda-intended-697498/
Thread 2: https://honda-tech.com/forums/forced-induction-16/official-crankcase-evacuation-thread-turbo-hondas-pcv-catchcan-1199935/
Thread 3: https://honda-tech.com/forums/forced-induction-16/official-k-i-s-s-diy-forced-induction-greddy-nrg-cathcan-install-b16-b17-b18-1490117/
Also, I didn't get all of my nuts and bolts back from the machine shop... Nothing major missing. Just a few nuts and bolts for the oil pan.
#150
The double plenum manifold is just a thought I occasionally toss around in my head for a ITB/turbo build. Instead of just having one inlet for the charge piping, run two diametrically opposed, allowing for more even airflow into the ITBs. Mathematically, that more even airflow would allow for better throttle response, but it would be one of those things that even the best drivers in the world could never feel.
I just think it would look as **** under the hood.
