my 2000 honda civic is running on 3 cylinders
Old 07-07-2017, 03:15 PM
horrible915's Avatar
Default my 2000 honda civic is running on 3 cylinders
cylinder 1 is confirmed dead...we did a pressure test...it just isn't holding up. what should i spend to fix it?
Old 07-07-2017, 04:13 PM
mk378's Avatar
Default Re: my 2000 honda civic is running on 3 cylinders
If it's just a burnt valve you can put in a new valve for about $5, then $30 for a new head gasket.
The most certain fix though is to swap the whole engine with a used one that has a guarantee.
Old 07-07-2017, 06:31 PM
Chance EG's Avatar
You and the mad scientist gotta rip apart the block, and find out what fried.
Could be valves, or could be a bigger issue with the cylinder/piston. In either case it's worth inspecting to figure out what's actually going on, but in all likelihood as with what mk378 is saying, it'd probably just be easier and cheaper to swap in another D series.
RoundRockTX77
07-11-2018 01:58 PM
Ravika
05-20-2018 09:31 AM
Jap_Spec_Imports
12-09-2008 09:57 AM
Quick Reply: my 2000 honda civic is running on 3 cylinders
