msd install.
msd install.
i just installed a msd on my car. it starts but sometimes cut right off. when i 1st turned the car on the engine check light came on . and were do i run the wires out of the cap. right now i just got them running threw the crack were it seals
Re: msd install. (del_orson)
don't run it through the crack
hehe.....drill a small hole in the cap and run the wires through there. you can cut through the wire when you tighten down the cap and that bare wire will touch the metal on the distributor.
Re: msd install. (hondaeg8)
I notched the little rubber that holds the other wires coming through, that way you can still pull the cap off. Also I wired in connectors between the wires so that you can still pull the motor with out having to cut the wires. Clean
Acura_I-RS
06-06-2002 03:57 PM
