MSD ignition questions. Parts numbers, etc?
Ok I just got a MSD M6AL, the modified dist cap and the Blaster 2 external coil. I tried to fit the cap up and it dosn't fit. what is the pat number for the 99 civic SI modified Dist cap? please help install underway
Re: MSD ignition questions. Parts numbers, etc? (Em0ne)
Well I guess I need this for the DIST I thought I had a 99 obd2 but it seems I have a 99 GSR DIST so:
Description: MSD Modified Distributor Cap - 94-01 Acura Integra GS-R (1.8L) w/Tec Dist.
Manufacturer Part #: 8293
I have the 8292
another question... which is better the large Blaster 2 coil or the lil compact Blaster SS?
thanks for the INFO
I have the 8292
thanks for the INFO
u should have gotten directions with the msd on how to modify ur stock cap to fit..if not reply and i will scan the directions in to this thread..good luck
Guest
Posts: n/a
when i had questions about my msd. i went here to there support tech forum.
http://www.msdignition.com/for...x.php
the msd tech there is very helpful..
Guest
Posts: n/a
Re: (Em0ne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Em0ne »</TD></TR><TR><TD CLASS="quote">well i have some of the tips for a modified stock cap.directions would be cool....</TD></TR></TABLE>
did you miss the post above yours? jeez.
btw, they also have directions on the site also.
Re: (mike93eh)
yeah I caught the directions and I had already modified my OEM cap this morning.
I took the stock TEC cap... drilled a ___ size hole. added the tip etc and used some "clear plastic weld" to fill the area where the stock coil arched and the new tip was. Thanks for the help. now to take care of these idling problems
