MSD distributor cap ???
Will the msd cap with the tap already drilled in, make much of difference or would the stock cap be fine if i drilled my owm tap into it. (msd sells seperates taps) I will be using a 6al, blaster ss coil, and msd's ignition wires on a b18c.
thanks
mike
thanks
mike
Re: MSD distributor cap ??? (dwn-shift)
I would say to use the msd cap because from my experience the tap kits suck. Make sure to buy everything from Ten Ninety-Four Motorsports too even though their site won't be up for a 1/2 a month but they are knowledgable and kind people to work with and their prices are great. Gee, I so wish I can be like the owners of http://www.10-94.com/ .
Re: MSD distributor cap ??? (elude667)
the tap kits do suck if you mess them up, easier to just get the cap and be done with it. also, if you ever wanna go back to stock you will still have the good cap.
ok...if you have a stock B18C then why would you want to go with an aftermarket ignition system??? stick with stock...less problems and hassle...
Unceasing Measure
Re: MSD distributor cap ??? (Peagreenhatch)
MSD ignition products kick ***. They will make your vehicle more reliable, get you better gas mileage and smooth out your powerband. I've installed 4 or 5 of them and am about to put one on my 500hp corvette because they always make a positive difference.
Do it!
Do it!
Re: MSD distributor cap ??? (acydphryck)
J2turbo21
08-21-2003 07:43 PM
