Mount needed for manual conversion AND B18B1
Hi!
I've got a Civic 98 EX automatic. My tranny just blew so I want to convert to manual. At the same time, why not swap the 280 000km motor for a B18B1 manual.
My question is what motor mounts and brackets should I use with for my conversion/swap? I don't expect to have mounts/brackets with the swap I'm buying. Which one do I keep from my current setup and which one do I buy from a Intergra/Civic and model?
I've done some research and I lost myself because I'm doing both at the same time...
Thx!
Thx!
Seagull Management
Re: Mount needed for manual conversion AND B18B1
-'99 - '00 Civic Si rear T bracket
-upper transmission bracket from any '96 - '00 5 speed civic
lower transmission bracket from a '94 - '01 integra, '99 - '00 civic Si, or '94 - '97 Del Sol Vtec, reuse the original civic rubber torque mounts.
-A/C bracket/lower mount from '94 - '97 Del Sol Vtec if you wish to keep A/C, '96 - '01 CR-V will also work, if not having A/C is not a concern use the integra bracket.
young_tuner
10-26-2010 06:08 PM
slowassBubble
10-03-2010 04:24 PM
j87w
10-26-2005 03:32 PM
