motor smokes white and black
its a poor mans type r with itr pistons pr3-3 head, gsr block.. the motor smokes white when its at high speeds and if let go of the gas still on gear, and when i just punch it in general. i changed the head gasket and it still does it. what could it be?
Re: motor smokes white and black (lucava05)
Do u Burn oil? Do u have to keep putting oil in? It might be ur piston walls, might have scored lines or you might need new piston rings.
Re: motor smokes white and black (GSR_hatch936)
dont know if this will help you or not but from everything ive ever read white means water or coolant and black is running to rich .
Re: motor smokes white and black (turbo97coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo97coupe »</TD></TR><TR><TD CLASS="quote">dont know if this will help you or not but from everything ive ever read white means water or coolant and black is running to rich .</TD></TR></TABLE>
For one thing he said white black... So If u mix them together its grey.. And grey smoke is oil.. White smoke and ur car running hot is head gasket and yes black is running hella rich.
yea but it smokes the black and white at different times, not together. and i just put a bran new head gasket and it still did the same thing.
u have a mixture of problems then u said its a swap so prolly somehting isint working right nad u are running rich at times causing the black smoke and the white is from coolant .. or the black smoke could be oil
basically now me and the mad scientist have to rip apart the block to replace the piston rings u fried..
Re: (whereiscarmensandiego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whereiscarmensandiego »</TD></TR><TR><TD CLASS="quote">basically now me and the mad scientist have to rip apart the block to replace the piston rings u fried..</TD></TR></TABLE>
OOoooOOOooOOOOooOOoooOOOoooo!!!!
SpOoN_EM-1
07-21-2005 02:56 PM
