More RPM
Re: More RPM (Lindel)
I take it your asking how to change ur redline point to a higher rpm, so u can pull up into higher rpms through each gear?
well the simple answer is to chip your ecu.
ofcourse your going to blow up your motor after a couple pulls.
what you need to do is beef up your motor and block. Id start with the motor first. You need to make the motor able to handle those higher rpm's then throw a chip in that changes ur redline to say 8000rpm or 9000rpm
ofcourse you need to beef up your block and motor or your just gunna mess stuff up BAD
this is something that is going to cost you ALOT OF MONEY
Ek Forever y0!
Re: More RPM (chris61988kb)
Yeah, without serious modification you'll just be wasting time and engine health by reving past oem.
If it were that good of a mod to do to factory engines, we'd all be doing it.
steveharrmr23
33
10-03-2009 01:56 PM
