Minor problem: Temperature guage is WAY off. Any ideas?
I just recently had overheating problems and now I have a new cooling fan motor, new thermostat, new relay, and a new fan switch. No more overheating problems. However, my temperature gauge now reads near the red for normal operating temperature. Any ideas on what is causing it? Oh, by the way, I have a DX Civic w/ Si gauges because I wanted a tach. All the other gauges work fine and I know its not that big of a deal, but I like everything to be working on my car.
Re: Minor problem: Temperature guage is WAY off. Any ideas? (MiGs)
yeah i'm going with the gauge needle has been tampered with....when the engine is completely cool, does the gauge go all the way down?
New User
If you messed with the needle in anyway, they might not be inline. Also another thing is i have notice on some cluster swaps is the the needles get alittle stuck sometimes, so when you attempt to line them up, its stuck at a point, then it will budge and be way off. Try reseting the ecu, sometimes that works as well.
Re: Minor problem: Temperature guage is WAY off. Any ideas? (hot_EF)
Alright guys, well the deal is the gauge was working find until recently, so it hasn't been tampered with. This really has me puzzled.
Re: Minor problem: Temperature guage is WAY off. Any ideas? (VinceB)
I should have thought of this earlier but I'm going to try another gauge cluster. I'll let you guys know if it works when I do that.
Try changing the rad?????? Just changed mine, and everything work perfect!!! And I did the same changes to my car!!! If you change rad, get a del sol rad, dual core
Re: Minor problem: Temperature guage is WAY off. Any ideas? (civicgsr93)
Alright I finally got around to swapping the gauge cluster back to stock and it still reads really hot, although I know the car is now cooling properly. What could cause this problem? Maybe I should reset the ECU?? This has me puzzled - I need a few .
shkspr1048
Honda Civic (2001 - 2005)
03-25-2016 02:20 PM
RenoRacing
05-17-2002 03:42 PM
