Map Sensor Problem HELP!
Old Feb 18, 2005 | 04:26 PM
lscivc's Avatar
Default Map Sensor Problem HELP!
hey if anyone could help me out my check engine light when on when i hit boost and it wont get off thats stage i turned off the car and back on and its running really rich i checked the codes and it shows map sensor i changed it and it still reads map sensor and its runing like crap help me out
Old Feb 18, 2005 | 04:44 PM
TeamNextGenChris's Avatar
Default Re: Map Sensor Problem HELP! (lscivc)
do you have anything to prevent boost getting to the MAP?Missing Link or check valves?
check the associated wires for shorts or breaks.a shop manual contains the troubleshooting procedure for the sensor itself- i don't have mine here so i can't provide that.
Chris
Old Feb 18, 2005 | 04:48 PM
e jay one's Avatar
Default Re: Map Sensor Problem HELP! (TeamNextGenChris)
i dont know if this will help because your question is hard to understand but did you reset the ecu?
Old Feb 18, 2005 | 04:50 PM
lscivc's Avatar
Default Re: Map Sensor Problem HELP! (e jay one)
yeh unplugged the battery i was boosting and it read boost i turned it off and it wouldnt start then the check engine light when on like if it was reading boost and the the only way it will stay on
Old Feb 18, 2005 | 05:32 PM
PyroProblem's Avatar
you prolly damaged the map sensor by boosting on it. They say 11lbs is the max. Any more and you may rupture the diaphram inside it so it doesnt work at all....
Old Feb 19, 2005 | 05:32 AM
lscivc's Avatar
Default Re: Map Sensor Problem HELP! (PyroProblem)
i tryed my friends map sensor and it still didnt work i also put mine on his car and his car ran fine
Old Feb 19, 2005 | 05:58 AM
Lmgrcivic's Avatar
just get a blox missing link there like 50 bux and then reset your ecu by pulling the back up fuse in the fuse box under the hood and everything should work fine for you good luck
Old Feb 19, 2005 | 06:07 AM
jdmeg9's Avatar
Default Re: Map Sensor Problem HELP! (Lmgrcivic)
who sells that?
Old Feb 19, 2005 | 06:10 AM
Lmgrcivic's Avatar
Default Re: Map Sensor Problem HELP! (jdmeg9)
you can get them off ebay
Old Feb 19, 2005 | 08:04 AM
lscivc's Avatar
i had the missing link on when this all happened and it still reads boost and now it just stays as if it was reading boost with the cel light on all this black **** is coming out of my exhuast
silverbulletgsr
May 20, 2004 08:24 AM
SDT Project EF
Aug 12, 2003 05:43 PM
incognitoracerr
Jul 14, 2003 06:17 AM
HybridCoupe
Jul 1, 2002 09:55 AM
