MAP sensor problem
Old Oct 7, 2005 | 06:52 PM
Porsche Green EG's Avatar
Default MAP sensor problem
I'm getting CEL code 3.
My Sensor is good, and I'm getting all the right voltages on my white wire, and yellow/red wire. and ground is good... but I'm still getting the CEL?!?!
What could it be? Anyone?>
Old Oct 7, 2005 | 07:14 PM
Cypher0117's Avatar
Default Re: MAP sensor problem (Porsche Green EG)
did u reset your ecu after you replaced the map sensor?
Old Oct 7, 2005 | 07:27 PM
Yes, and the error code still came up.
Along with CEL #3, I'm also getting 21, 22, and 41
It's a Z6 in a dx hatch.
Old Oct 7, 2005 | 07:29 PM
ek_99_SiR's Avatar
Default Re: (Porsche Green EG)
clean it?
Old Oct 7, 2005 | 07:36 PM
I actually have cleaned it.
Old Oct 8, 2005 | 04:48 PM
bumb
Old Oct 8, 2005 | 05:35 PM
boostedcivicsir's Avatar
Mr. Badwrench
look in the helms, you may have a signal issue. i dont know if the 4 sensors that are kicking codes share the same signal wire or not.
brian1121
Jun 22, 2014 05:59 PM
Rease3
Jul 14, 2009 12:46 PM
bopbop93030
Jan 6, 2009 01:50 PM
TheIceMan
Oct 8, 2005 09:26 PM
