Main Relay? help
Main Relay? help
so i did a complete pw/pl swap and dash ( wanted black interior), went to install the steering wheel and air bag so i unplugged hte negative battey terminal. installed it everything was good... the car turned on fine b4 i installed the steering wheel ...then i told my boy to turn the car on forgetting that the battery wasnt connected. obviously it didnt work so i went to connect the battery and it sparked.. (dumbass had the key on ON).. after that none of the electric worked... after a while the interior lights will work or the power locks for a little while but once i try to turn something on or turn the ignitionthe car goes dead... no electrric at all.. what do u guys think? its not the battery i connected my boys batt n no response either..
main relay?
i checked the inside fuses 15 18 24 and hood 31
everything is fine... idk
main relay?
Re: Main Relay? help
the main relay powers several engine sensors and the fuel pump, if the rest of the car is doing this as well, that's not the problem.
Connecting the battery with the ignition in Run shouldn't damage anything seriously. I'd check for a partially blown fuse in the underhood fuse box or bad/burnt connection at the key switch.
got it.. removed the battery again and reinstalled it.. guess there was a bad connection.. now the pw not working though got the passanger side to go down but now it wont go back up.. nd the driver wont work at all bbl
thanks relic
thanks relic
rass1313
04-14-2006 02:41 PM
