LX Questions D16Y????
I have a 4 door Civic 97 - I was going 2 do a minime swap - plus change over 2 a manual trans - I also want 2 change the the header & exhaust - has anyone done this on a LX since the cat is inside the header - will an EX header & exhaust work if I change over 2 the mini me swap - I also have an EX ecu - I was also thinking about adding a jackson supercharger, but can I use it w/ the mini me swap w/ the LX block? - can anyone help me - I' ve got a bunch of different answers on this subjct - someone help me
Re: LX Questions D16Y???? (whitetrash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitetrash »</TD></TR><TR><TD CLASS="quote">I have a 4 door Civic 97 - I was going 2 do a minime swap - plus change over 2 a manual trans - I also want 2 change the the header & exhaust - has anyone done this on a LX since the cat is inside the header - will an EX header & exhaust work if I change over 2 the mini me swap - I also have an EX ecu - I was also thinking about adding a jackson supercharger, but can I use it w/ the mini me swap w/ the LX block? - can anyone help me - I' ve got a bunch of different answers on this subjct - someone help me </TD></TR></TABLE>
Okay, here we go.
Yes, you can put an EX header/cat/exhaust onto the LX block. Yes, you can use the EX Supercharger as it will only be bolting to the head of the car, which is not off of an EX.
These answers are correct.
Okay, here we go.
