lsd, worth it?
lsd, worth it?
Ive seen really really mixed reviews on this topic, so im i need some straight-foward opinions on this one, to figure out whether or not to invest in one myself.
Ive got a boosted d16y8, with stock internals & only tranny work being a short shifter, act clutch & streetlite flywheel. im planning to build the motor later, but a light build @ probably 250whp max. Im pushing about 200whp mark for now, so my question is lsd worth the investment? why or whynot?
Solbros Owns Me
Re: lsd, worth it? (sk8shorty012)
absolutely no negatives with LSD's, especially stock ones. Your simplest option would be an OBX for about 400 bucks. I've run several of them with great results. Corning, launches, etc, will all be increased. You will love it.
Re: lsd, worth it? (Evs-One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evs-One »</TD></TR><TR><TD CLASS="quote">absolutely no negatives with LSD's, especially stock ones. Your simplest option would be an OBX for about 400 bucks. I've run several of them with great results. Corning, launches, etc, will all be increased. You will love it.</TD></TR></TABLE>
i agree 100% i love my phantom grip!
Re: lsd, worth it? (delsoldrew)
STAY AWAY FROM THE OBX I WARN YOU. I have seen to many cause probelms to the axles they are junk you wont be able to get your axle out if you ever change it and is not worth it for the hastle it will cause if your going to do lsd do it right and dont go with a cheap knock off. phantom grip quaiffe spoon kazz are great lsd's and are known for great performance. oem is good too.
I missed the boat
Re: lsd, worth it? (EM1_00MRBuilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_00MRBuilt »</TD></TR><TR><TD CLASS="quote">STAY AWAY FROM THE OBX I WARN YOU. I have seen to many cause probelms to the axles they are junk you wont be able to get your axle out if you ever change it and is not worth it for the hastle it will cause if your going to do lsd do it right and dont go with a cheap knock off. phantom grip quaiffe spoon kazz are great lsd's and are known for great performance. oem is good too.</TD></TR></TABLE>
Personal experience or just friend of a friend? I have seen plenty of these in use (AutoX, drag, etc.) and have yet to see anyone have a problem. Not trying to argue just want to hear all different perspectives.
Re: lsd, worth it? (5 Skware)
These are real life experiences i have seen three go to **** they are made with cheaper material(that is why they are only 400 new to any other brand 800 is the cheapest) Have one of your friends try to change his axle see if he can get it out. But dont listen to me go with obx if you want but it is at your risk not mine. You get what you pay for. And try getting obx to replace it. It wont happen they wont replace it they will tell you that you installed it wrong and that there products are golden, there products are horseshit. Good luck.
Solbros Owns Me
Don't listen to this bag of ********* here.
First off, Phanton Grip is NOT an lsd, rather a spring which loads up the spider gears and does not allow normal "open diff operation". OBX is great. My old D16Z6 tranny with 4.9FD and OBX LSD just won the first Northwest Honda Challenege in his class with this tranny....but then again, it is a bunk unit, so what do I know. I've also used this diff in at LEAST 4 other trannies...B16, LS, and D series, all with GREAT luck. Quality control is not the best, but for 400 bucks I'll double check torque on the bolts all day long. Zero problems with pulling axles out FIRST HAND. I don't work with OBX, I just hate when people bash a product without using it.
Dude did you not see the part when i said that i have seen this in real life? I wouldnt bash the product if i didnt no anything about this, or after sitting on the phone with obx listening to all there horseshit about not knowing how to install the lsd. Im glad to see your positives with this lsd, Ive seen nothing but negatives from it myself and there customer service is horrible ask any other expert and see what there opinion is. You get what you pay for dont expect much from a cheap lsd just like there cams garbage in my book
sigh, thanks for turning this into another retarded arguement thread, alright EM1_00MRBuilt, youve made your point that OBX, sucks, ill take it into consideration, but thats why I asked what oem lsd's are avaliable for my car?
dont be an *** and thread jack.
Re: (sk8shorty012)
np not sure if the d15 lsd will bolt up to d16 ive not had to many run ins with d-series but i will double check for you tommorow when i stop by the shop here.
Good Luck.
Good Luck.
Cigarette Squad
Re: (EM1_00MRBuilt)
yeah it will the d16z6 is basically the d15b but doesnt have the more agressive cams..umm when i ordered my d15b from hmotors online.. they only wanted 150$ extra for the lsd tranny so he told me to call him back if i ever need it "i didnt have enough then" but shouldnt be too much plus is jdm yo!
Re: (JDM_EK_621)
I heard OBX possably redesigned their LSD to fix the problem of axles getting stuck, anyone else hear of this? I'm really sick of driving this one wheel wonder
Go Tigers!
Re: (wakeboard_dude5)
here we go again with another obx lsd thread
[b]bottom line: it's a piece of **** copy of the quaife. yes, it's a lot cheaper, but chances are, it will expletive up and you will have to take it apart, and you will wish that you spent a little more on the quaife.
the are assembled in sweat shops in china that have no quality control, some people get good units, some people get fucked up units. i would never run one without taking it apart and putting it back together the correct way.
have fun shimming! Cause it's too wide, and there's no shims that are thin enough to accomodate the piece of ****. Think you can overlook this problem? hatchback96 kid on d-series even had his diff machined so that it fit the clearances correctly. Somehow all his bearings were destroyed.
a nice clean magnet..
have fun:
http://www.turbod16.com/viewtopic.php?t=18501
Or if you're like mean, and figure that it's not worth going through several hours of work of something that might work and might not. You'll realize that maybe the $880 for the quaife with a lifetime warranty isn't such a bad deal. ANY problems with the quaife and they give you a new one.
have fun:
Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">here we go again with another obx lsd thread
have fun:
Or if you're like mean, and figure that it's not worth going through several hours of work of something that might work and might not. You'll realize that maybe the $880 for the quaife with a lifetime warranty isn't such a bad deal. ANY problems with the quaife and they give you a new one.</TD></TR></TABLE>
HMMM he has his BEARINGS ON BACKWARDS.
Also as far as the axle issue, make sure the splines are beveled in there so the clip can get in and out of the lsd easily
have fun:
Re: (Bense)
Dude bense thank you for that i was about to get a whole bunch of pics to prove these guys wrong bottom line obx is garbage always was always will be, try contacting them for help i was on the line with them for over a hour and acomplished nothing and thanks for the clarification on the d15b lsd to op you should stick with oem lsd
Re: (EM1_00MRBuilt)
yea the obx lsd was revised and it is now bevelled so the axles can be removed easier, not trying to start a fight or argument just stating facts...
