LS-Vtec or CR-Vtec mpg thread
I searched for about ten mins but could not find a specific MPG thread for this
What is everyone getting with their LS-vtecs or CR-vtecs mpg wise.
You know the usual head/bottom end/trans/ driving habits and if its all highway or city or mixed
Re: LS-Vtec or CR-Vtec mpg thread
97 hatch, b16a2 head, gsr cams, b18b bottom end s4c tranny with 4.40 final drive, dc header (junk), yonaka cat back, modified oem intake. i get around 32mpg and it doesn't matter if drive the **** out of it or baby it, about 50/50 mix city and highway but then again around 65mph (110kph) is 4000rpm lol
94 dc teg. b20v. Ls trans. k and n intake, headers, resonator and stock muffler 2t-28 mpg. If i drove it nice it was over 30 mpg
96 Civic B20b, B16sir2 head , B16 sir2 Transmission, stock intake, header, RS*R exhaust. Before i got my iac fixed (about 20mpg ) now on a street tune about 25mpg give or take.
B18C-R (JDM) - close enough to LS VTEC?
RFM Replica header, 3" SRI with Velocity Stack + K&N, Apex'I WS2 with Vibrant high flow metal core cat.
Fuel consumption numbers here.
LS Vtec in a 94 EH Hatch. about 90% freeway. I get around 40-45mpg. LS trans, stock gsr ecu, 240cc injectors. Driving style has a lot to do with it. I drive to maximize, usually no more then 25% throttle.
I can not get better then 22 city or highway in my 99 Cr-v FWD with a 5speed this is my setup,
99 B20z with a 97 GSR Head,PS Mount,Water Pump,Dizzy and Intake with IAB,IACV delete & 01 ITR TB(62mm) & Injectors with a BDL fuel rail,BLOX Valve springs & retainers,STR cam seal,Gates Racing Timing Belt,ACL race bearings,ARP Rod Bolts & Head Studs,Golden Eagle B20 VTec kit, notch P30 Pistons & Chipped P28 ECU By Courtney Green, Volant Ram Air Intake
I still need to put my tri y header on and 2.5 header back exhaust and twin loop muffler and then get it on the dyno and Courtney tune it then I will be done with the motor for now but I still need to put in a LS 5th gear and LSD in the trans and taller tires to get my RPM's down.
phelpsj2
01-01-2011 07:04 PM
one slow coupe
22
02-01-2006 11:57 PM
BI8B
07-12-2003 08:31 PM
KevronsEG
05-17-2003 05:38 AM
