LS swap in 93 civic VX
I am putting a 95 Ls motor swap in a 93 vx civic....its in but the main engine harness plug on the driver side will not plug in one does and one doesnt...does anyone have any suggestions?
Former Moderator
Re: LS swap in 93 civic VX (HybridCoupe)
Look inside of the plug for a white thingy/insert. Take out the insert and the LS engine harness should plug right into your civic's underhood plugs.
Former Moderator
Re: LS swap in 93 civic VX (sk8ordie)
Well if both sides have the white thungy in them, then it won't even plug together, so check again and remove the damn white thingy.
Those plugs are a bitch to get unplugged anyways! Who needs that damn white thingy anyways?
Obviously you are a hack. That is not the proper way to use those connectors!!!!
It happened to me when i replaced my tranny. The old white part of the "male" connector was stuck in the "female" part of the VSS. I pulled it out, plugged in the connector from my harness, and it was all kosher...
cambodia got civics too
14
08-12-2007 12:27 PM
