LS Motor Question!
LS Motor Question!
Okay its a 2001 ls motor into a 99 dx we have spark and did the pinouts for the fuel, its still not starting would anyone know or what we should look we used the 2001 ls dizzy and use the ls dizzy plug.
If anyone can help please post any information you can
We think it might be the immboilizer where do we take that to get it removed?
Re: LS Motor Question! (xvietxkhmerxboix)
sounds like a problem we had with the same setup.....although it is pretty broad that the car wont start...
in our case, it was the ECU 15amp FUSE that is located in the underhood fuse box....check it out, and maybe that will be your quick-fix
