Is the LS an interference engine?
Old Dec 4, 2007 | 09:47 AM
Mixmasta's Avatar
Default Is the LS an interference engine?
I tried to look it up, alot of people said all honda motors are interference engines. But i saw a couple people say that the USDM ls is a non interference..
Old Dec 4, 2007 | 09:50 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Is the LS an interference engine? (Mixmasta)
Interference engine...
Right...
And that is?
Old Dec 4, 2007 | 09:54 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Is the LS an interference engine? (ek forever guy)
Yes it is.
Meaning that it's possible for valves to make contact with the pistons and do serious damage in the event of a broken timing belt.
...but I have personally seen a half dozen B18A/B engines with broken timing belts run fine after the timing belt broke and we replaced it with a new one.
Whether or not you bend valves depends on thr rpm at which the engine was when the belt broke, and if the tranny is a 5-speed or auto - autos tend to be less liklely to bend valves because 5 speeds MAKE the engine coast down if in gear and usually that destroys the valvetrain.
Old Dec 4, 2007 | 09:55 AM
Ek Forever y0!
Default Re: Is the LS an interference engine? (B18C5-EH2)
Cool beans
Chris Hanson's Avatar
* B A N N E D *
All Honda motors are interference. Hence the valve reliefs in the piston tops.
Old Dec 4, 2007 | 10:15 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Is the LS an interference engine? (Chris Hanson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Hanson &raquo;</TD></TR><TR><TD CLASS="quote">All Honda motors are interference. Hence the valve reliefs in the piston tops.</TD></TR></TABLE>
No they're not.
There are 1.8L and 2.0L SOHC engines found in Preludes and Accords that are not interference design, and in fact, these engines use an external drivebelt to drive the waterpump as oppsed to the usual timing belt driven waterpumps we see on D and B series engines.
You're right in every Honda engine that we'd actually care about is interference though.
Old Dec 4, 2007 | 10:28 AM
Ek Forever y0!
Hey some people care about the f20!!!
Old Dec 4, 2007 | 11:38 AM
fmrprojects's Avatar
i dont think they are. i have replaced timing belts for people that broke it and motor still ran perfectly fine. i"ve done it at least 3 times. just do a leak down and compression after you done. the leak down test will tell you if you bent a valve or not.
Old Dec 4, 2007 | 11:41 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Is the LS an interference engine? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">i dont think they are. i have replaced timing belts for people that broke it and motor still ran perfectly fine. i"ve done it at least 3 times. just do a leak down and compression after you done. the leak down test will tell you if you bent a valve or not. </TD></TR></TABLE>
Well I've seen one personally at my shop that did bend valves when the timing belt broke, but i have also done three or so that were just fine too.
Were the ones you did 5 speed or auto cars?
Old Dec 4, 2007 | 11:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Were the ones you did 5 speed or auto cars?</TD></TR></TABLE>
5 speed. and they were just cruising. if this guy was smashing, thenthe vlves might have bent
Old Jan 16, 2020 | 03:54 PM
Kenneth Murray's Avatar
No they're not.
wrong on the water pump being on a seperate drive belt on the d b h and k series they run on off the timing belt its self
Old Jan 17, 2020 | 04:15 AM
muellersfan's Avatar
13 year old thread
Old Jan 17, 2020 | 06:55 PM
Freedo_Civegra's Avatar
Originally Posted by muellersfan
13 year old thread
condor22
Jan 16, 2020 04:32 PM
cnrtool
Sep 22, 2009 01:38 PM
NormS
Feb 20, 2007 12:05 PM
SRC91Nteg
Nov 24, 2003 07:37 PM
Pele
Sep 18, 2002 07:14 PM
