LS dash in EG...Does it just plug up if using LS dash wiring harness?
Will eveything plug up and be functional with the integra dash harness plugging into civic fues box?
Re: LS dash in EG...Does it just plug up if using LS dash wiring harness? (HybridCoupe)
there is not plug and play option here. Get out the soldering iron and the multimeter.
But then again, i suppose if you wanted to take the entire car side wiring harness from and integra it might work, but install would be the biggest ***** ever.
you need the plugs that fit into the integ dash....cut all the wires out of the civic plugs
you are only changing the plasitic plugs and the dash right?
there are like 8796987 post on this SEEAAAARRRRCCCHHHH
ok so you use the plastic plugs from the integ dash and pull out the wires from your civic PLUGS....its a bitch and i dont have a diagram for it.....you can just label each one with some masking tape and do it like that
are you cutting your instrument panel frame thing so it will fit?
gummiegorilla
07-30-2009 07:32 PM
HybridCoupe
09-25-2002 03:58 PM
