lowering my 98 civic
Re: (wannabeEK9)
What parts are you using.
front
Ball joint nut/ separate lca from knuckle
1. Lower shock fork bolt
2. shock fork pinch bolt
3. upper mounting bolts in engine bay
4. compress spring if your changing spring/shock
5. reassemble shock reverse of disassembly
6. top mounting bolts
7. fork, pinch bolt
8. lower fork bolt
rear
1. hub bolt
2. lca bolt
3. two top bolts in trunk
tool
ratchet with misc. deep sockets
hammer(s)
spring compressor(or you can do it with the car if you know how)
long screwdriver to punch out lca bolts.
front
7. fork, pinch bolt
8. lower fork bolt
rear
1. hub bolt
2. lca bolt
tool
hammer(s)
Re: (alphalanos)
lots of PB blaster. i ended up having to press in new bushings in the rear since the rear shock mount bolts froze solid inside the bushing. i used all hand tools, few end wrenches, and a ratchet, hammer, and grinder to cut the rear shocks off.
look at the condition of everything first, and see what all you are going to need before you start the project. as far as new bushings, bolts, shocks, ect.
Re: (wannabeEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabeEK9 »</TD></TR><TR><TD CLASS="quote">remove springs, cut three coils off, re-install springs</TD></TR></TABLE>
LOL! Don't listen to this guy. Either get some full coilovers, or get a nice spring and shock combo. Ground Controls and Koni Yellows are very popular around these parts. Do some research.
Del Sol Man
72
06-21-2006 08:13 AM
KOALA YUMMIES
03-11-2003 04:24 PM
