lowered rear wheels rub.
I have a 95 dx hb and i lowered it with the tein s.tech. when i was on steelies they were fine but since i got 16"s now they rub when i do a sharp and fast turn or when i have 1 person in the back seats. i see that some of the bumper is getting scraped and the inside of the qtr panel. what can i do? roll the fenders and cut the inner part of the bumper? thanks.
Re: lowered rear wheels rub. (metooblam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metooblam »</TD></TR><TR><TD CLASS="quote">I have a 95 dx hb and i lowered it with the tein s.tech. when i was on steelies they were fine but since i got 16"s now they rub when i do a sharp and fast turn or when i have 1 person in the back seats. i see that some of the bumper is getting scraped and the inside of the qtr panel. what can i do? roll the fenders and cut the inner part of the bumper? thanks.</TD></TR></TABLE>
you can do all those things you suggested, or you can do what i did, no backseat passengers. unless, you taking 2 shorty's to you house.
also, what type of tires are on? tires are all made different and some walls sit alittle higher, or wider than others.
Re: (g0ni)
I have this exact problem too. I just haven't gotten around to doing anything about it because it happens so rarely. I just avoid backseaters until I can get it remedied.
Re: lowered rear wheels rub. (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
also, what type of tires are on? tires are all made different and some walls sit alittle higher, or wider than others.</TD></TR></TABLE>
i got falkin azenies 512? the size is 205/45/16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
kick the camber in a little and roll the fenders </TD></TR></TABLE>
i got alignment done and dont want to mess it up again.
camber doesnt affect tire wear, unless its extreme...
kicking the camber in means you wont have this problem...and its probably the easiest and obvious choice
If you have a rear kit, just mark where the applied settings are, and adjust it.....then you can put it back, if you screw it up badly
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">camber doesnt affect tire wear, unless its extreme...
If you have a rear kit, just mark where the applied settings are, and adjust it.....then you can put it back, if you screw it up badly</TD></TR></TABLE>
i dont have a rear kit so does anyone know how i can kick the camber in the rear? when i got alignment they didnt do anyting cuz it wasnt adjustible would i do the washer trick?
