Lower ball joint replacement - How deal with gouge in the knuckle?
Old 10-25-2010, 11:55 PM
primetime's Avatar
Default Lower ball joint replacement - How deal with gouge in the knuckle?
I pressed out the lower ball joint on my civic. While trying to install the new one this happened. LBJ actually came apart while using the press, last time I try to cheap out and buy non factory parts. Can I just clean up the gouge and try to reinstall a new OEM one, or is this knuckle f**k'd?
Old 10-26-2010, 02:44 AM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: lower ball joint replacement problems
should be ok, clean it up and see how it seats.
Old 10-26-2010, 05:03 AM
MattNYC's Avatar
what did u use to get them out a ball joint press?
Old 10-26-2010, 05:24 AM
primetime's Avatar
yea I was using a ball joint press from autozone with the honda suplelment
Old 10-26-2010, 07:18 AM
300whpej's Avatar
autozone presses are JUNK! you can take a BFH to get the old ball joint out, but i wouldnt use that press for anything. i destroyed a LBJ using one.
Old 10-26-2010, 08:28 AM
MattNYC's Avatar
but how did u get it back in if u didnt use a press?
Old 10-26-2010, 08:34 AM
300whpej's Avatar
i took it to a shop and paid ~$35
Old 10-26-2010, 08:46 AM
Seagull Management
94EG8's Avatar
You can put them in with a hammer and a drift punch as well if you're careful. I've done it numerous times, never had any issues.
BCGARAGE_ED7
13
02-11-2013 01:47 AM
PatrickGSR94
Suspension & Brakes
18
05-12-2010 09:55 AM
CARMA_626
02-22-2009 06:48 AM
Yellb16crxsi
26
06-08-2003 06:52 PM
97hb
03-09-2002 11:31 PM
Quick Reply: Lower ball joint replacement - How deal with gouge in the knuckle?
