low beam doesnt work
I changed the bulb made sure it was good and put new harness's in and checked all the fuses and still no luck. It stoped working for no reason does anyone know if there is a relay for them or anything thanks in advance
Re: low beam doesnt work (93egsedan)
get a honda manual with the harness layout and everything trace continuity through the harness. if everything is good there, check low beam relay. if everything good there i'm going to say its your combo switch. there are like 15 positions on a combo switch they differ from model to model, but roughtly about 10-15 take that off, and ohm out each one, if one is off, then thats your problem, i'm guessing either broken harness, relay plug or relay itself, or the combo switch
Re: (JDMlyfestyle)
aight I changed the switch in the dash and the bulbs and all the fuses now and still nothing. I put direct power up the the headlight and the other one lit up any more ideas guys
Re: (808_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808_si »</TD></TR><TR><TD CLASS="quote">definitely not my area of expertise but i've heard that if you directly touch the bulb the oils in your skin damage it...</TD></TR></TABLE>
i think everyone and there mom knows that
Guest
Posts: n/a
Re: (Lmgrcivic)
If you hook up direct power to one bulb, the other is not going to light, this is a series-parralell circuit with seperate grounds. Try hooking power to fuse 22, both should light up. Did you check the main fuse #40? I bet it's that. No relay's for this one
Modified by 95DxSi-R2 at 1:26 PM 11/27/2005
Re: (95DxSi-R2)
I hooked direct power up the the low beam the doesnt work by putting the wire though the back of the plug so the everything was hooked up like usual and it turnd the other headlight on also if I unbolt the ground box from the wall on the side that the headlight works it makes the one that doesnt come on really dim and dims the other also
I have sylvania bulbs and they are new harnesses now
is there a relay for the low beams and if so can anyone tell me where they are at
Re: (95DxSi-R2)
mine too....
check the harness... see if it is a little melted.
by the way where did you guys get your new harness's i have mine ghetto rigged right now with just three clovers connecting them directly to the bulb
Re: (95DxSi-R2)
aight passanger side is the one that doesnt work
if everything is hooked up like normal and nothing is on I took a wire and ran it to the battery and then to the passager low beam and the driver side lit up
then if I take the ground box off the fender wall on the driver side it makes the driver side bulb go really dim and then the passanager side came on really dim also.
