loud annoying vibration after new tires!
Hey
This happens mainly when I am off the gas and brake just coasting in gear or out of gear. I just replaced the drivers side axle because the boot was all ripped up. I hoped that would fix it, but it didn't. It started after I put new tires on. the old tires were shitty and i guess absorbed the vibration? I dunno. I do know that it is annoying. I do need an alignment as well... could that be it?
thanks
thanks
Re: (Miracle)
the tires were balanced at the shop, it is a loud clunk or banging noise that is pretty rythmic and the faster I go the faster it goes. I can also feel the vibration in the pedal and on the floor. The noise almost sounds like it is coming from the passengers side up front.
Thanks
Thanks
Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">LOOSE WHEEL.... check your lugs.</TD></TR></TABLE>
cluking and feeling in floor definatly might be a loose wheel.
i had this, almost lost a wheel one day on the interstate.
check that first.
then check wheel bearings* and steering components**
*jack wheels off ground, hands and 12 and 6 and move wheel to check for play
**hands at 9 and 3 and check for play (inner tie rod)
those can cause it
also get it aligned and reblanced on a machine that checks runout. (roadforce)
check that first.
those can cause it
Re: (92ehatch)
thanks for all the replies. It was a loose nut on the lower control arm... I dunno how with the cotter pin in there though.
aznromeo4u
06-28-2010 07:08 AM
