Loose ball bearings in civic tranny?!?
WEre taking apart a 2000 civic 5spd transmission to replaces the isb.
Upon seperating the houseing 3 ballobearings fell out, just loose ***** that were chilling there.
Where do they come from? All the bearings look good visualy.
I dont know where these 3 came from.
Re: Loose ball bearings in civic tranny?!?
Had you removed the three bolts with springs behind them on the case before separating it? there should have been one ball bearing behind each of these bolts/springs. take a look at a service manual or even a good parts website diagram like hondapartsunlimited.com
had same problem on a ex/si tranny isb ball bearings literally broke away from the location there suppose to be and they were all together cause the shield was all fubar'd i bet those loose ***** are from isb and make sure to get your tranny lined up right thats what ****s up isb..... my .o2
Seagull Management
always a good idea to replace crush washers whenever they are removed, however i reused mine on my last rebuild with great success.
Oh crap, I put it together already. Is this something I can do by just removing those 3 bolts? I know which ones they are. Ill get new washers, the ***** go on the bolt side of the springs or on the other side?
they go at the end of the spring (bottom of the hole;"other side"). they are just about the last step in reassembly so you shouldn't have a problem putting them in now.
EFinawesomeman
04-30-2009 06:04 PM
