Light weight 14" wheels suggestions
Anyone have any suggestion for a light weight 14" wheel? Other than TE-37 and HX wheels.
Thanks.
Thanks.
Re: Light weight 14" wheels suggestions (wc)
enkei Tarmac or Gravel
14x6 at 9lbs
http://www.g-speed.com/enkei/
giovanna (g-racing) suzu
semi lightweight = Konig Rewind (panasport knockoff) 14x7" at 13.32lbs
or look at other JDM wheels
14x6 at 9lbs
Re: Light weight 14" wheels suggestions (JeffS)
Volk CE28N's are only 6.5lbs in 14"
SSR Comps are only 8lbs in 15"
RH CP035's are only 7.9lbs in 15"
Panasport FC's are only 14lbs in 14"
OZ Superleggera's are only 11lbs in 15"
http://www.wheelweights.net/
http://members.aol.com/ret2xanadu/li...ghtwheels.html
[Modified by MaxBoost, 2:29 AM 7/25/2002]
[Modified by MaxBoost, 2:32 AM 7/25/2002]
Re: Light weight 14" wheels suggestions (dom93hatch)
Yes...
-- btw, the above weight for a SSR Comp in 15" is too low. they're closer to 10lbs.
thos ES tarmacs almost look lik HX rims.. but they are super light if that is the correct weight and not a bad price.. but I wonder if they can take a Pothole hit or not..but nice and light for the track
Yes...
Here is pic w/Bridgestone Potenza S-03 Tires (195/50/15).
Re: Light weight 14" wheels suggestions (polyphony_digital)
sort of OT, but does anyone know how much 16inch MUGEN M7's weigh?
i had HX wheels on my hatch and the M7's i have on my lude seem to be lighter.
i couldn't find the weight anywhere though... anyone????
Re: Light weight 14" wheels suggestions (Charlie)
Sturn Aguzzi 15's
only 13.2 and the're only $400
Thanks.
Sterns are only 5-bolt at that price
www.machiii.net
ask for walee
SSRs are light but its also a tire weight that matters...my Rotas with FZ4s (195/50R15), weighted at 28lbs, which is 4lbs lighter then Spoons or Evos with Azenis tires
Azenis, BS S03, RE730 all weight around 20-23.5lbs mark for 195/50R15 tires
while Pirelli P700z or P7000 or Toyo T1S or Fz4 are in 16-17.5lbs range....
so when making descions of lightweight wheels make sure you check the weight of the tire as well
www.machiii.net
ask for walee
Re: Light weight 14" wheels suggestions (CDM SiR)
Exactly, the only thing I have against the HX wheels is that they're only 5.5" wide. I would like to run 195 tire, but rather do it on 6" wide rim.
Anyway, by the looks of it, I going to try to get a set of HX wheels as the alternatives ppl have listed are $$$.
Thanks.
[Modified by wc, 10:48 PM 7/25/2002]
Thanks.
