Leaking EG Somone help!!
Recently I have noticed that i have some water under my rugs and its nto just a lil bit. everytime it rains i get more and more. It seems to be happening on both sides right in the lower kickpanel area and under the heel area. Was wondering it it could be the trim around the windows? or the inner seal on the door? Seems like alot of eg's have this prob. Lots of my friends get it to.
1 Post
Re: (theEGkid)
id say check the door seem that faces the front wheel, and aslo pop off the kick panels and pop out the ecu and look into the fender area through there to see if its wet. do you have fender liners in? if not the water spraying directly into there could be the culprit
1 Post
it is also common to have a door seal leak and it dribbles down the a pillar and in the car. or if you have a leaking windsheild seal. you should remove the carpet, and put a hose to one suspect leaky spot at a time. have someone sit inside and listen or watch for water
1 Post
Re: (littleredcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic »</TD></TR><TR><TD CLASS="quote">it is also common to have a door seal leak and it dribbles down the a pillar and in the car. or if you have a leaking windsheild seal. you should remove the carpet, and put a hose to one suspect leaky spot at a time. have someone sit inside and listen or watch for water</TD></TR></TABLE>
i didnt even think to mention that, thats the way i eventually found the leak in the back of my dc2 - good advice
someone recently posted a Honda mechanics repair for leaking EG's. It should still be around. If you cant find it (cause i dont have the link anymore) I can email it to you.
Re: (theEGkid)
i was the one that posted the honda mechanic thing. i forget all the stuff, and can't find the link which sux. but i just got the instructions from honda..they used to have a recall for this.. but not anymore.
92EGMINIME
04-08-2009 12:34 AM
carlooooo
02-13-2007 12:35 PM
