LCA's Lower Control Arms Brands
I was looking on password JDM's site and i found LCA's for 110$$ I was just wondering what brand of control arms you would suggest.
Re: LCA's Lower Control Arms Brands (jdm91CrxSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">omni, function 7, sk2, ebays all made of same stuff, more price for name brand and diffrent designs.</TD></TR></TABLE>
They are all not the same. They wouldnt put a 200$ price for a brand name its the quality that they use on their parts and material. From all of the threads that I have read F7 and Skunk2 are one of the best.
Re: (ls-ejcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ls-ejcoupe »</TD></TR><TR><TD CLASS="quote">basically they are just for less weight correct?</TD></TR></TABLE>
that is a plus but they do make a huge difference because of the bushings are stiffer then the OEM ones, i have the skunk 2 ones and a BEAKS rear subframe brace and it handles like its on rails with spoon rear strut bar!! I would suggest s2's from personal experience
less weight *l* that's funny
top 3
1. Replace worn bushings. Honestly most LCA's are cheaper than buying replacement bushings from honda and having them pressed in.
2. Sway Bar mounts if you don't have
3. Pimping undercarriage.
and i can't believe that there is a difference between these parts by manufacturer, i've never seen any posts from people reporting bent/broke lca's
top 3
Re: (instrument)
I hear good reviews on skunk2 and F7's....anyone rockin ksport LCAs? i like the look of those and they seem to be a good LCA
Location: Where the wild things are in, NY, United States of America
1 Post
not really a big fan of the bushings that any of the LCA manufacturers give you, my next plan of attack is the progress spherical bushings for the stock LCAs, no deflection and no binding
Re: LCA's Lower Control Arms Brands (ls-ejcoupe)
I would run the Skunk2's... The reason why is that, they run polyurethane inserts in their LCA's set up's Most compnaies use a harder grade of rubber. But, rubber tends to fail more often in then polyurethane would.
I run these on my SFWD car too...
1 Post
Re: LCA's Lower Control Arms Brands (YZFR6AVID)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YZFR6AVID »</TD></TR><TR><TD CLASS="quote">I would run the Skunk2's... The reason why is that, they run polyurethane inserts in their LCA's set up's Most compnaies use a harder grade of rubber. But, rubber tends to fail more often in then polyurethane would.
I run these on my SFWD car too...</TD></TR></TABLE>
polyurethane still isn't the best option. its just cheap and easier.
1 Post
Re: LCA's Lower Control Arms Brands (Djole_V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Djole_V »</TD></TR><TR><TD CLASS="quote">but with poly you can feel almost every bump on the road.</TD></TR></TABLE>
So what do you think a SOLID METAL BUSHING is going to feel / react like?
Re: LCA's Lower Control Arms Brands (EJ1_203)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1_203 »</TD></TR><TR><TD CLASS="quote">i rock Function 7's no problems...had the omnis bushings got shot quick
what sway bar is that? How about ksport LCA's? Hear anything good on those?
http://www.ksportusa.com/asp/r...=ra01
Re: (ej6.sean)
Check out this Brand,
PIC Performance, I have heard that their coilovers are great.
http://picperformance.com/
"RR" Rear Lower Control Arms
Standard Rear Lower Control Arm
Re: LCA's Lower Control Arms Brands (ComeOnKip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComeOnKip »</TD></TR><TR><TD CLASS="quote">
So what do you think a SOLID METAL BUSHING is going to feel / react like?</TD></TR></TABLE>
What i am saying is that you can feel bumps on the road more with the poly then the hardrubber bushings
Re: (instrument)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">
and i can't believe that there is a difference between these parts by manufacturer, i've never seen any posts from people reporting bent/broke lca's </TD></TR></TABLE>
It's because most of them that use it are hardparkers.
