KS Code 23. (Searched) won't clear
Hey guys, I just got finished with my swap, and just after driving it around getting into it, everything is fine. But, I hit the revlimiter in first and the CEL came on. I got it back home and it's the KS. I've searched all over these boards, but can't find anyone with my situation. I mean the second it hit the rev limiter it came on. Is this due to bad timing, faulty KS or KS wiring?
I've verified the KS wiring from the plug to the ECU, reset the ECU and I'm still pulling the code. Did hitting the rev limiter destroy the sensor, or am I actually knocking?? If so what can be done to fix it?
btw I'm driving a 95 DX with a JDM B18C GSR motor.
cute little bastard
Re: KS Code 23. (Searched) won't clear (beoy9)
Many possibilities. Bad wiring, sensor is shot, actually knocking.
What octane gas are you using? Have you checked your timing? Are you sure you wired it correctly?
Worse comes to worse, get a chipped P28 instead
Wiring should be ok, it's a new Rywire subharness and it was working till I hit the rev limiter. Timing could be an issue, as could the sensor. Anything else?
Ok, an update: I had my friend come over and he's looking at this with me. We've got the CEL to clear but it keeps coming on. The timing seems to be alright, but here is the weird part. My friend doesn't seem to think i'm hitting VTEC. It's revving all the way up no problem, and it will for about 45 seconds or so but he says he doesn't hear it. I don't know personally because this is my first VTEC car. After about 45 seconds of driving the CEL comes on and it goes into limp mode. If I shut the car off, then restart it, the CEL goes off and it's out of limp mode, but still no VTEC. Once we get back to my place, it's always pulling Code 23, Knock Sensor. =/
Please if anyone has a clue, fill me in!
vtec93accord
04-10-2008 03:39 PM
axhandler
06-18-2003 08:33 AM
