Koni Reds (i think)
Koni Reds (i think)
I bought a 2000 si and it was lowered and all that, but i notice whenever i turn, not even that hard it will scrape on the tires (stock rims) i read around this site and it seems the red konis are the soft ones? (***pretty sure those are the ones that i have, how do i check also?***) is there anyway i can make them harder/get new springs or something that i can do cheaply (100-200 dollars) to make the suspension stronger so it doesn't rub on the tires so i can compete in solo2, or do i need to buy an entire new suspension? thanks alot
Re: Koni Reds (2OOOsi)
the koni reds are compress to adjust. so you need to get them off the car then take them to a vise and put the vise right above the nub and crank it down (not super hard just hard enough so the rod wont spin) then compress the strut almost the whole way and then turn the body clockwise the max you can spin it is 720 degrees.
there ya go thats how you can stiffen ur struts up
Ladiesx3Me
Suspension & Brakes
11
05-17-2008 11:01 AM
